Dust Collection
Subject: Re: Single phase industrial unit
4/23/20
Jason Member
I'm looking for a new dust collector for my professional shop. We currently have two separate 3hp units connected to different equipment and I want a single unit that can handle 1 to 3 tools at a time. The largest tools for dust collection are a 53" Timesaver and a 24" planer. The big issue we have is that we need the unit to be single phase and it must be located inside the shop per city code. Any suggestions on a unit to look at that is reasonably priced would be appreciated.
4/24/20       #2: Single phase industrial unit ...
Dustin orth
Are you running your 53" time-saver on single phase? If not then why the single phase requirement? How much chip type dust do you produce? Or mostly finer dust? Biggest motor for a collector I've seen in single phase is 10 hp, but personally I would get a phase converter for a better industrial collector. I have 2 indoor units and one big outdoor but I produce lots of chips and fluffy dust from making moldings so my indoor units are a pain, bags and barrels fill to quickly. You don't have a choice if the unit has to stay inside but a bigger collector should have a larger storage capacity. My biggest indoor unit is 10HP and has 3 55 gallon drums. How much space can you dedicate to a collector? How far is it going to be from your breaker panel? A long run in single phase for a big motor is going to be expensive for wire. Do you need this to be a single stage or 2 stage unit? How tall are your ceilings? When you get most of these answered, you will start eliminating different collectors due to restrictions on that data.
4/24/20       #3: Single phase industrial unit ...
Jason Member
Hi Dustin. Here is some additional details.
My Timesaver is on a 60hp phase convertor. I only run the Timesaver for maybe an hour per day and it is a little bit of a pain to turn the phase convertor on as it is in another room. I would prefer to not run a 60 hp phase convertor for 8+ hours per day for the dust collector since the collector runs most of the day, thus the need for single phase. I could add a separate phase convertor, but due to electrical codes and location of everything, it will cost more for the electrical than the collector to do this.
I produce 70/30 chips to fine dust. I would love a larger collector (my two now each have a 55 gal drum), but I'm thinking 2-4 drums is probably all I'll end up with. A local farmer picks up all my sawdust and I just dump it into bins for him, so it works well enough.
I have 10 foot ceiling in the shop everywhere and 13 foot in between rafters with plenty of floor space if needed. I have a conduit and wiring in the area already so pulling new wires shouldn't be too bad.
Thanks for the help.
4/24/20       #4: Single phase industrial unit ...
Dustin orth
Look up extrema machine, under the typhoon brand they have a cyclone unit that is 7.5 hp single phase. It might fit your space, maybe. It would be tight as its pretty tall. I would go with a cyclone unit as the barrels are way easier to deal with than bags. I had this unit in 3 phase years ago and I wish I hadn't sold it. Worked really nice and had 2 drums under it. Price isn't to bad for something that can pull everything in a smaller shop up to 2-3 machines at once. It is an industrial unit, not an upgraded hobby machine. May be worth looking into.
4/25/20       #5: Single phase industrial unit ...
larry
Dont forget to count total amps.
5/4/20       #6: Single phase industrial unit ...
I am a big fan of units like the Dantherm.
http://www.wwthayer.com/Dust-Collectors-Dantherm-Filtration-Dust-Coll
ectors-S-Bag-Filter.asp
You can get a 7.5 hp single phase. They are quiet with the correct amount of filter area. You can also get a hopper that goes under them and dumps with a forklift.
Belfab also has nice units. They have hoppers the pull easily and can be dumped with a fork lift. You can also get more filter modules so more filter and waste capacity.
https://www.pyradia.com/dust-collectors/products/open-modular-dust-co
llectors/?keyword=modular%20dust%20collectors&medium=ppc&network=g&gc
lid=Cj0KCQjw-r71BRDuARIsAB7i_QNhq7mfuoCsbIZnj6ZOCGcf13Ke-MnRsgopW0HIUBKrveOO1aF_1
KUaAo6QEALw_wcB
We have had a small (15hp) cyclone on a wide belt and it works, the one we had was noisy.
I question how you run a widebelt on a 3hp collector?
Good luck!
    • GreCon
    • Air Handling Systems
    • Sandman Products
    • Denray Machine
    • RT Machine Co.
