Dust Collection
Flex hose for CNC, everything is splitting in less than a year
6/14/22
Matt
We process 20-30 sheets per day on our 5x10 CNC router, roughly 1/3 plywood and 2/3 common domestic melamine. I know melamine is abrasive.
Anyhow, I'm finding that my dust collection flex hose just doesn't last as long as it seems that it should. Our machine has one main 8" hose and several 6" and 4" hoses across the gantry. The only one that moves a lot is the main 8" diameter drop.
All the rest of them seem to split at about the same rate as the main 8" drop, it's getting kinda wearisome replacing $600 in dust hoses every year.
I've been buying various brands of urethane, and I need them to be static dissipative. Can anyone suggest something that might last? My only real needs are something flexible to handle being the main drop for the CNC and is static dissipative. I'm just unimpressed with what I've seen from urethane.
6/15/22       #2: Flex hose for CNC, everything is sp ...
chris
give Air handling systems a call.
they advertise on this site.
6/26/22       #3: Flex hose for CNC, everything is sp ...
david zaret Member
Website: http://www.curlandburl.com
Wynn Environmental sells really nice, heavy duty polyurethane hoses. i've had great luck with those for heavy duty use.
9/7/22       #4: Flex hose for CNC, everything is sp ...
Jamison Scott  Member
Website: http://www.airhand.com
Matt, I hope you found a solution for your flexible hose needs. Yes urethane is the answer, but there are various thicknesses .020, .025, .028, .030, .035, .045, etc. For this application, we usually recommend .028 or thicker. In addition to getting the proper hose, I always recommend rotating and flipping your hose to change the wear points, as all hose does wear down over time.
As for surface resistivity, there are hoses that are anti-static and static dissipative just be sure to check the ohms. Anti-static hoses: < 10 9 &#937; and static dissipative hoses are usually 2x10 10 &#937;
9/13/22       #5: Flex hose for CNC, everything is sp ...
Mike Member
Website: http://rulonco.com
I've tried them all and the best to date is the Flexaust FLX-Thane MD
https://www.flexaust.com/product/abrasion-resistant-woodworking-hose/
It cost a little more, but worth it.
    • Denray Machine
    • Machinery Associates
    • Sandman Products
    • American Fabric Filter Co.
    • RT Machine Co.
    • GreCon
