Kremlin AAA Spray Pump Is Skip Spraying -- 0 --
10/14
Website: http://www.superiorcabinetryandmillwork.com
Hi, I've got a Kremlin 20:25 AAA spray pump that is skip spraying. Guys sometimes call it "winking". If I'm not mistaken, it does it every time the piston starts to stroke downward. Every time I hear the piston change direction and start downward, the finish coming out of the gun will stall for just a quick second. It is definitely aggravating when you are spraying a large cabinet. Do you guys know what I need to do to fix it? I would appreciate any help. Thanks in advance.
10/15 #2: Kremlin AAA Spray Pump Is Skip Spra ...
Your pump would be skipping a stoke if you have a stuck ball.
take the bottom foot valve off and clean it out.
Put back together and you should be good to go.
If you leave the pump in the down stoke when not being used overnight or for the weekend, it would help to prevent this form happening in the future
10/15 #3: Kremlin AAA Spray Pump Is Skip Spra ...
did it just start doing it , winking or did it just coming up
two things, like bob said, clean out the bottom ball check, take your time removing the clip that holds it in, it can be a pia
good luck
herb j
10/15 #4: Kremlin AAA Spray Pump Is Skip Spra ...
Thanks guys. I appreciate your advice. I took the lower part of the pump off and took the lower ball out. I checked everything and everything seemed to be fine and was totally clean. I ended up taking the pump to my local repair shop this afternoon. It turns out that there was a small crack in a plastic air fitting. It was a 90° fitting that came on the pump from the factory. The repairman said that he had seen that happen before. I guess it was sucking air through that crack in the fitting as it cycled. If anyone else has this problem, you might want to check your air fittings. It was a fitting on the right side, as you face the pump. Thanks again, guys.
10/21 #5: Kremlin AAA Spray Pump Is Skip Spra ...
thanks for letting us know very interesting learn something new every day
10/22 #6: Kremlin AAA Spray Pump Is Skip Spra ...
You are welcome. Hopefully, that information will help some other folks.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
