Subject: Re: Wire Brushed white/gray oak
1/15/15
Jarin Smoker  Member
I have a finish sample that i have been asked to replicate for a projet that we are doing. It is a deep wire brushed oak floor board. We have been asked to make table tops in this same finish. We have the makita wire wheel sander to wire brush it. Then I am thinking a gray dye stain, sealer white glaze, topcoat? We use a lot of Ilva products and will probably use their poly and their stains. Any input would be great.
Thanks,
Jarin
1/15/15       #2: Wire Brushed white/gray oak ...
You'll probably have to go closer to black than gray for the base color.
1/17/15       #3: Wire Brushed white/gray oak ...
DCS
Jarin,
This process is called Cerusing, which is a filled grain finish. You will need to experiment on samples to get colors set, but essentially, your finish schedule will work fine...
Good luck, DCS
