Subject: Re: Stealth drying problem
4/20/15
JohnB Member
Website: http://woodmanseewoodwrights.com
I sprayed the first coat of MLC Stealth over Clawlock primer. Used the proper catalyst, at 10%, but after 2 hrs. it is still slightly tacky. Shop was a little cool, around 62 degrees, but I've sprayed at similar temps before with no issue. The cat. is a little old, not sure if there is a shelf life on it or not, but it seemed to work fine with the primer coat. The Stealth is fresh, not sure if I just need to wait longer or what. Anyone see similar issues with Stealth? If I have to throw out this batch I can, but it's a custom color so I can't waste too much without ordering more which doesn't fit the schedule well. I didn't thin this batch either, just cat & stealth. Maybe better to thin a bit?
4/20/15       #2: Stealth drying problem ...
Kevin Member
Don't have a ton of answers, but I was told once by my Campbell rep that the catalyst doesn't really have shelf life. Stealth needs to be reduced, 20-25% with Care Reducer (after cat). Wouldn't think this would affect dry time, but probably best to start there.
4/20/15       #3: Stealth drying problem ...
monty
Temp has everything to do with cure, of course reduction does as well. Acid cured products cure when the catalyst is added at recommended values. if the temp is lower than "normal this will retard the cure. Try and warm your shop to 70 plus degrees, you will see a difference. this also goes for the drying cycle. Once the product has flashed you should be able to slowly add heat and cure the coating. Heat +air makes a huge difference. Good luck.
Monty
4/21/15       #5: Stealth drying problem ...
JohnB Member
Well, I turned up the heat a bit later yesterday, but when I went out to the shop this morning, no change. Everything is still tacky to touch. I'll try my rep as soon as he's in this morning, but it's looking like I'll be stripping off this coat and starting new. I'll be spraying some samples first though. Good thing I started with the backs of the doors first, and only hit two vanities, not all the other cabinets, as they are a different color. Thanks for the input guys.
4/21/15       #6: Stealth drying problem ...
monty
I would agree, your paint rep should look at this. Sounds like catalyst issue if it is still tacky. Good luck.
4/21/15       #7: Stealth drying problem ...
Rick Mosher
Once the catalyst stops working it doesn't start again when you turn up the heat. Just like putting it in the refrigerator to use it the next day. You need to keep the temp above 65 degrees while spraying and curing. Should say that on the PI sheet. If you don't you could also get cold checking.
4/21/15       #8: Stealth drying problem ...
JohnB Member
Talked to rep, he said it did sound like a catalyst issue. I'm grabbing some new, also their reducer, try it thinned 15-20%. I'll keep my fingers crossed!
4/21/15       #9: Stealth drying problem ...
Leo G
I have found a pretty good thinning mix to make Stealth work very well. I thin it 25%. I use 15% Reducer and 10% Flow Enhancer #2. It's a perfect finish almost every time. Flows out very well in cooler weather.
4/22/15       #10: Stealth drying problem ...
JohnB Member
Thanks Leo, I'll try that. What equipment are you spraying it with? I'll be using a CA aaa setup, but I'm curious what others prefer.
4/22/15       #11: Stealth drying problem ...
Leo G
Kremlin 14.10 with an AirMix gun.
