Subject: Re: water spots on maple veneer
4/22/15
Jim
Cleaning up yellow glue with water and stiff brush or steaming out dents on maple veneer leaves a dark spot you can't see until you stain. Sanding the raw wood, or after the stain is inadequate. What are guy ou doing to the clean glue without waterspots.
4/22/15       #2: water spots on maple veneer ...
ThomasFR
Had a training guide when I was teaching (& re-teaching) my crew. The '"prep" section included this rule: "What you do to one square inch of a surface, you do to the entire surface". Water swells wood fibers & opens the pores. You must wet the whole surface uniformly or end up with "thirsty" areas which absorb more stain, creating blotches. Easy to confirm how severe this can be with some test panels. Others may have suggestions on methods of avoiding your procedure for glue removal. Good Luck.
4/22/15       #3: water spots on maple veneer ...
Charles Member
Are you using distilled water? Regular tap water, or well water, has a lot of minerals. Those minerals may be causing some of your problems. I don't know for certain if that is causing your issues, but I tend to lean towards being very cautious.
I buy steam-distilled water at the local food store for about 97 cents per gallon in a plastic jug. Just be sure you grab the distilled water and not the purified drinking water. They are usually located next to each other.
4/22/15       #4: water spots on maple veneer ...
I never scrub up glue with water and a brush. If you have to do that, you are using too much glue. I let glue stiffen slightly, then cut if off with a sharp chisel. It's not leaving a dark spot if you can't see it. As mentioned, you are leaving a spot of swelled grain. I have trouble in the summer with sweat drops, does the same thing.
4/22/15       #5: water spots on maple veneer ...
monty
Thomas is dead right. If you put water in one spot. do all of it. Then re-sand per your SOP.
4/22/15       #6: water spots on maple veneer ...
