Subject: Re: WB coatings issues
WB coatings issues
6/18/15
Dan Collier Member
Hi All
We are having some trouble with our wb top coats in white and clear where we are left with either the orange peel affect on the finished product or when we thin more we are left with tiny air bubbles that will not disperse completely.
we are using a Lemmer T90q 4 stage turbine sprayer and a 1.3 tip
I have checked air flow and temperature in the building and have performed many test pieces but cannot seem to get the in-between that i need
it has been suggested to use a
reducer instead of water any thoughts on this ?
Or what we can use as a reducer rather than ordering the ICA recommended brand
6/18/15       #2: WB coatings issues ...
Jim
Dan
Refer to post dated 5/27/15 in this forum. ""New spray systeams"
They work great when they don't leak. If I use mine know I wrap a rag around the clear cup/black lid joint.......then keep an eye on that. I try to never use more then 3lbs. Pressure. With the PPS pressureized system you have more speed and can spray upside down. Always, be watching for leaks. ......!
6/18/15       #3: WB coatings issues ...
Shane
You shold find a source for Ethyl Glycol to add as a reducer/retarder to your waterborne. It will extend the flash off of the top film and allow more of the pinholes you are seeing to escape. Try shhoting with more atomizing air and keep it minimal on your wet thickness should help also.....also some people have issues with water if it is not distilled water that you are reducing with.
6/18/15       #4: WB coatings issues ...
Dan
Thanks Jim I actually have the PPS system cup we are using it right now.
Thanks Shane
I have never thought of the distilled water issue
I know for sure we are not using that
I have picked up some ICA reducer from another company to try.
Will Update on the outcome
Dan
6/19/15       #5: WB coatings issues ...
Denny J
I have sprayed WB for approaching 2 decades and generally speaking the orange peel effect is fixed by adjusting the air/fluid settings until you can lay a good wet coat.
I have sprayed WB's with everything from 12 dollar harbor freight guns to AAA pumps and you can get a great finish with any of them if you set up the fan pattern and hold the gun the right distance from the product.
The biggest challenge in training people to spray WB is to hit that fine line between having a heavy enough coat to wet the surface without orange peel and yet thin enough that you don't get runs.
I will say that the biggest step in spray quality came when I bought the Asturo 10GP gun for my turbine and on smaller scale projects I actually get a better finish than I get with either of my AAA units.
6/19/15       #6: WB coatings issues ...
Dan
The problem has been solved by using a reducer.
and some knowledge from the ICA sales rep .
Because we live in prairies its pretty dry and low humidity which has been causing the product to not settle correctly
I tried probably ten test pieces to try without using the reducer to fix the issue but with no luck.
We added 3% of the D1072 reducer to the water and it worked perfectly first time.
Thanks for the Help all.
6/19/15       #7: WB coatings issues ...
Shane
Dan,
Can you tell us if that reducer has glycol in it from the data sheet or msds? Just curious.
6/19/15       #8: WB coatings issues ...
Wayne Weber Member
There are a number of issues here:
No such thing as ethyl glycol. Perhaps you are thinking of ethylene glycol which is antifreeze and is extremely toxic-not something you want to use and spray in your shop. Also it will never dry so it will be in the coating forever.Some people use the term glycol to mean a specific compound but in reality it describes a class of compounds with two hydroxy groups. A slight difference in the structure of the molecule makes a huge difference in their properties-for example ethylene glycol is toxic but propylene glycol is registered as a food additive.
7/23/15       #9: WB coatings issues ...
Shane
Sorry for my mistake... I was actually trying to say adding propylene glycol as an additive to slow down the flash off time not ethyl glycol..... Propylene glycol is used as a retarder in waterborne finishes and will help solve any microbubbles.... Sorry for the confusion and wrong advise...
