Subject: Re: tiny specks in clear coat
6/18/15
Gforce77 Member
I had posted a message some time back about having small black specks in my clear when I sprayed over my pigmented finish, I have found out it was in my material, I have strained it through a medium mesh strainer, then I still couldn't get it all, I tried straining it through panty hose, heard that from a painter, its better but still tiny pieces showing up, what should I strain with to get it all 125 micron filters? It is a lacquer finish btw.
6/18/15       #2: tiny specks in clear coat ...
Mastercabman
How much of that stuff you have left?
Why not get fresh product and call it a day?
6/18/15       #3: tiny specks in clear coat ...
Gforce77
I've noticed it in 5's and gallon cans just Everyone of them has it. This is the only product I've used, you only see it on white, and it's minuscule , but it drives me crazy. Is this normal having to strain clear coat with this issue?
6/18/15       #4: tiny specks in clear coat ...
Mastercabman
Well if you have this problem with the product I would take it back where you got it from and get your money back!
Get something else
BTW what brand is it?
I never seen dirt/crap in any of my finish product
Also I use the 3m pps and the lids has a mesh to filter any dirt
I think you can get 125 micron and 200 micron lids
6/18/15       #5: tiny specks in clear coat ...
Gforce77
It is Sherwinn Williams cab acrylic clear / /Sherwood.
6/18/15       #6: tiny specks in clear coat ...
Denny J
I have seen the same thing from Aqualente and GF Poly. During the glaze/distress fad it got very frustrating to deal with it. We first thought it came from the cotton rags we used to wipe off the glaze and to wipe down between coats but it ended up being in the product. There were white and red strands and I never got an explanation of what the cause was but it was frustrating.
6/19/15       #7: tiny specks in clear coat ...
Shane
it's the lining in the can sometimes... where the seam in the can is oxidizes and little junk disperses throughout your coating.... had the same problem and strained it once with ultra fine strainers and rinsed with solvent... put under a 200X pocket microscope and it looks like rust.....
