Subject: Re: Help with creating finish
8/25/15
Chris Member
I have a project in the works and I'm getting stumped trying to create a similar finish provided by the interior designer. The wood is white ash and I thought I could duplicate this look but I'm having difficulty. A single tone 'pickled' look is a piece of cake, but this two tone is a bit challenging. I may be chasing a look made with photo veneer though!
Any suggestions?
View higher quality, full size image (1677 X 1789)
8/25/15       #2: Help with creating finish ...
JeffA
I don't want to make this sound easy but it looks like you will need a dark gray or black stain as your first coat. Then seal and when it's dry sealer sand with 220 or whatever grit you usually use. Blow off substrate and glaze with a white glaze, let dry and clear coat. If the glaze hangs up too much you may have to clean it with some solvent before clear coating. Just make sure the surface is dry before applying the clears.
8/25/15       #4: Help with creating finish ...
Robert Member
What have you already tried that's now quite working for you.Like JeffA mentioned you can shoot for a Grey/Black background and after a sealer coat a White glaze can be applied and wiped off. The White stays in the pores.
You might try and open the pores a little by coaxing a Brass bristle brush over the surface. Just go with the grain. Ive had good luck using a Brass BBQ Grill Brush for this purpose.
8/26/15       #5: Help with creating finish ...
Leo G
Spray the wood with a black stain or paint, seal it, use a gray glaze or paste filler to fill the grain. Apply a sealer coat. Then finish as usual.
8/27/15       #6: Help with creating finish ...
Chris Member
Thanks for all the helpful suggestions! I think the step I was missing was to seal off the dark base 'stain' prior to the light grey glaze. My last sample looks like a perfect match! Now to see what the interior designer has to say.
