Subject: Re: General finishes white undercoat
9/18/15
al
If spraying soft maple will GF white undercoat hide the grain? I will be putting GF pigmented poly over
it. I called GF and they said to just use Zinsser BIn and eliminate the undercoat. I have done this in the past and sprayed their white poly over the Bin and it indeed hides the grain. This will be going on a bathroom vanity and using shellac as primer worries me.
Any thoughts appreciated,
Al
9/18/15       #2: General finishes white undercoat ...
Dave Edgerton  Member
yup, that primer will work perfectly. dont bother with shellac.
9/18/15       #3: General finishes white undercoat ...
al
Dave are you saying to use the GF undercoat?
9/20/15       #4: General finishes white undercoat ...
Bart
Here's what I do. Put on a coat of GF undercoat then if any dark spots are showing through I hit them with a rattle can of zinnsers white shellac based stain blocker. Let it dry and rough with scotchbrite and then another coat of undercoat. If you still have any show throughs spot spray more stain blocker and top with some undercoat. Then 2-3 coats of poly-pigmented. I have by mistake used the oil based bin stain blocker without problems but I like to use the shellac based stain blocker.
