Subject: Re: finish edges of new kitchen cabinets
10/20/15
jim
I have several kitchen cabinet boxes to finish, a lot of them have only edge tape on front 1/2 inch wide, I need to stain and clear them, rather than masking the all off so as not to spray into box. anything I could brush on that will look nice.
10/20/15       #2: finish edges of new kitchen cabinet ...
RobertJ
Shellac! Quick and easy. Or, Deft brushable lacquer. Or, Wax.
10/21/15       #3: finish edges of new kitchen cabinet ...
Kevin
i have done hundreds of kitchens that were already assembled and used to make short work out of the cabinets by using a wiping stain and precat lacquer.
No need to tape it off, all i do is use a 8" x 14" piece of cardboard as a spray shield.
Hold the cardboard to the inside of the prefinished cabinet about an inch behind the edge. Move the cardboard with you as you spray along the edge. Keep a few pieces of cardboard near, so you can change out as they start getting too wet.
Also keep a can of lacquer thinner and clean rags near so you can wipe out any overspray. SOOOO much faster, cheaper, and easier than taping and masking.
10/22/15       #4: finish edges of new kitchen cabinet ...
jim
Robert and kevin thanks for your input. I have sprayed with a shield before, but always looking for a different way.
10/31/15       #5: finish edges of new kitchen cabinet ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
You don't say what the finish or the sheen is is on the rest of the cabinets but I have had great results just wiping a sealer coat of 2k urethane with a rag, scuff sanding with 400 grit and then wiping on a top coat of 2k urethane. Don't wipe too hard or you'll take off the previous coat but I could do a good size batch of cabinets in 1/2 hour.
Water based clear works really well wiped on as well as shellac which can be wiped or padded on.
We also had a hand held UV curing light which was REALLY cheating.
