Subject: Re: Smelly finish
Smelly finish
12/11/15
Craig Member
Hi all, I do some repair work for a production custom furniture company. About two months ago I was asked to look at two dressers that the homeowner was not able to use because when they placed their cloths into the drawers they would come out smelling like the finish. This was after they had been sitting for about three months.
We removed all the drawer boxes and the backs to the dressers and placed them in a room with fans blowing on them for about 3-4 weeks. The smell seemed to go away until we put the drawers back in. We also blew fans on the inside of the dressers themselves.
The company uses NC for a base coat, then acrylic sealer and top coat. This is an opaque finish with pewter powder (I believe). The drawer boxes are finished with lacquer.
Should this thing be off gassing for almost 6 months? What could cause this, and is there anyway to stop the smell?
Thank you!
12/11/15       #2: Smelly finish ...
Howard Member
Aside from the odor, is the finish in good condition? If it is, typically shellac is used as a barrier to odors like cigarette smoke. Generally shellac adheres to most finishes, so I would get dewaxed shellac and apply to a test spot. If everything is good to go, then the easiest thing to do would be to spray it.
12/11/15       #3: Smelly finish ...
Mastercabman
What does it smells like?
12/11/15       #4: Smelly finish ...
Leo G
Put it in a room and bring the temp up to 110F for 3 hours or more. Put everything in the room.
12/12/15       #5: Smelly finish ...
Tom
We had a very similar problem with a foreign sourced side board. Anything put into it would come out stinking; even glassware. I coated all of the inside surfaces with Seal Cote and the stink is gone.
I have read that wood, esp. some foreign sourced woods, can get can contain some organism that generates the stink and about all you can do is seal it in. I've also read the manufactured woods can "off gas" and smell bad until they've aged a bit. In order to smell like the finish, the inside surfaces would need to be finished and if the finished inside surfaces stink, the outside should stink too?? More likely the inside surfaces are not finished and you're smelling something beside finish. Best bet: seal the inside surfaces.
12/12/15       #7: Smelly finish ...
Craig Member
thank you all for your responses. Mastercabman, It smells like finish. Tom, I think I have read about the problem you had, and that is a bacteria, if I'm not mistaken. That's not the issue we are having. Howard, the finish is in good condition. We have used Shellac to seal out odors in the past, I just wasn't positive if it would work to good effect on this issue. One fear if I shellac it is, what happens to the off gassing? It has to go somewhere, right? Have you had experience with this?
Leo, what you said is interesting because the homeowner said the pieces of the dressers that were in direct sunlight seem not to smell. Will the heat speed up the off gassing even at this late stage?
I am assuming that the reason for the smell is off gassing. Is it true that this is the only reason the finish would smell?
Again, thank you all for your wisdom!
12/12/15       #8: Smelly finish ...
Leo G
At the high temperature the curing process is greatly sped up. It's very likely nothing bad can happen in the short time at those temps. Just don't burn the place down LOL
