Subject: Re: waterborne primer, anyone use Kilz Max?
12/26/15
alex whitefield Member
I am currently using BIN over Baltic birch plywood. I want to switch to all waterborne, my makeshift spray booth is not set up for oil base paints. Any suggestions on waterborne primer? I have used aqualente primer in the past and really enjoy it but it is difficult for me to get. I am painting PPG Breakthrough over the top with solid colors.
12/26/15       #2: waterborne primer, anyone use Kilz ...
Hen Bob Member
Wurth Baer Supply carries MLC Aqualente, they should be able to ups ground ship it to you
12/26/15       #3: waterborne primer, anyone use Kilz ...
John Member
Agualente WB Pigmented Primer is also available at Pond Cove Paint.
John
Pond Cove Paint - Aqualente WB Pigmented Primer
12/28/15       #4: waterborne primer, anyone use Kilz ...
al
John,
I clicked on the link you posted. According to what came up the primer is highly flammable.
I thought this primer was water based.
12/28/15       #5: waterborne primer, anyone use Kilz ...
John Member
You're right, which is strange because it's listed under the waterborne heading. So I looked directly at ML Campbell's website and found the link below. What you want is W123859. I would call Pond Cove and see if they sell it. Personally, I use BIN shellac based primer. It works great, clean up is not hard, just rinse/dunk everything in ammonia, and I can buy it locally. It's viscosity is around 30 seconds #4 Ford cup, so it sprays great with my pressure assisted HVLP gun with a 1.1 mm needle/nozzle. It should spray well with a gravity feed HVLP gun with about a 1.4 mm orifice, too.
John
Link
12/28/15       #6: waterborne primer, anyone use Kilz ...
John,
I like both BIN and aqualente primer, Aqualente is about a 2 hour drive to get for me and I would rather keep my input prices down and buy something local, shipping also adds to that cost. The BIN is a great product except for the horrible chemicals that are in it. I have a nice respirator but the stuff just stinks. I always worry about something bad happening with all of a alcohol vapor in the air with my makeshift booth.
I bought a gallon of the Kilz Max and tried it out last night. It lays down nice and has minimal grain raise for a waterborne primer. It sands to a powder but will cause some build up on the paper. I was $33 dollars at home depot. I had to add a little bit of water to push it through my awata hvlp.
12/28/15       #7: waterborne primer, anyone use Kilz ...
John Member
Glad that worked well for you Alex. But don't think that water borne products are chemical free, just because they use water instead of some volatile solvent or carrier. There are some chemicals in many water bornes that are far worse health wise than the alcohol in BIN Shellac primer. BIN has ethanol and propanol; that's it. Far worse stuff is in many water bornes, including ethylbenzene and toluene. The take away is always wear a respirator when spraying these things and ventilation is a good thing.
John
12/28/15       #8: waterborne primer, anyone use Kilz ...
Mike Fuson
I use chemcrafts aquaprime. Like it really well. I'd check and see if they have a distributed near you. I also like their pigments and topcoats.
