Subject: Re: Sherwood grey laq primer Product #
1/22/16
Joel
I used some Sherwood primer on someone else's job once and it was great stuff. It was grey, laq based, and filled plus sanded very well. I would like some but the local SW guy needs the product number to order. Their website doesn't list this. I would prefer a non catalyzed primer so the extra doesn't potentially go to waste. Please post if you have this info. Thanks...Joel
1/23/16       #2: Sherwood grey laq primer Product # ...
Shane
Why not use E63W5 Kemvar White primer..... this is an excellent acid cured primer and has awesome build and sanding characteristics. tough as nails too. With going with this post catalyzed material you can mix the amount according to your immediate need with no waste. you will essentially have a much better primed substrate than with a nitrocellulose base and the solid content is much much better, thus giving you a much better fill. especially on mdf edges or priming millworks that has mill marks. Just agitate and pour off what you need and catalyze.... here is the link to the data pages http://www.sherlink.com/sher-link/order/ProductDetailLoad.do?catalogProduct=true&a
mp;rex=E63W00005
and a handy link to look up any Sherwin item#
mp;rex=E63W00005
Sherwin Look-up
1/23/16       #3: Sherwood grey laq primer Product # ...
Joel
Thanks Shane
