Subject: Re: using airbrush for touchups
2/11/16
Dan Cook
We have used an airbrush for touchups ei. scratches or surface scuffs, however getting rid of the halo effect has been problematic. I had a furniture repair guy come in and he did the same type of touchup using an airbrush, but sprayed some kind of clearcoat over it from an aerosol can that seemed to make it go away. I know it was a Mohawk product but didn't see what it was. Is anybody familiar with this type of product for touchups. He just used our ML campbell magnamax white paint to do the touchup.
2/11/16       #2: using airbrush for touchups ...
eddie
It's called "Perfect Blend". M102 products. That is the solvent solvent base product. It also comes in a water base. Just make sure you shake it well before spraying. Great product.
2/12/16       #3: using airbrush for touchups ...
Dan cook
Ok. I knew there had to be a product from Mohawk that could do the trick. I had tried using retarder but by itself it didn't quite do the job of melting it in.
