Subject: Re: refinishing cabinets
3/26/16
Chris
I recently worked on a set of cabinets where I had to take out a couple of existing cabinets and make smaller. I was able to use the existing doors and drawers just had to cut down the cabinet and face frame. Everything went well until I started refinishing the face frame. I don't know what this woman used to clean her cabinets but it was not going to let me spray any lacquer on them. I sanded all the way down to bare wood twice and re stained but no it kept looking like oil floating on water. I built new face frames, What can I do in the future to avoid this ??
3/26/16       #2: refinishing cabinets ...
Chris
I got reading in the knowledge base on this form and answered my own question. But you still would think by sanding as much as I did that I would have sanded out all the silicone that can be some wicked stuff.
3/26/16       #3: refinishing cabinets ...
D Brown
Next time try washing with TSP .
3/26/16       #4: refinishing cabinets ...
Bob "Boardman" Bordere Member
You can also try adding a few drops of a product called "Smoothie", or others like it. It contains some silicone and is much less work than sanding or washing
3/26/16       #5: refinishing cabinets ...
RobertJ
"DAWN" dishwashing soap. May or may not work. It only costs .99 cents to try.
3/30/16       #6: refinishing cabinets ...
Pat
Automotive wax and silicone remover like R-M Pre-Kleano. Apply multiple times. Wipe with a clean rag each time.
3/30/16       #7: refinishing cabinets ...
Thom
All refinishes should be sprayed with mineral spirits in a simple spray bottle. If there is any silicone contamination it will show up like oil meets water. If it's there then scrub with acetone, wiping regularly and hope for the best. If it persists, then fisheye flow out can be used, but I recommend only distributing it by cup gun and NOT putting it through your spray rig.
3/30/16       #8: refinishing cabinets ...
Chris
Hey I had to refinish another drawer front I took your advice and washed it good with TSP and tried to spray some lacquer over it and it looked like oil on water. So I stripped it down with lacquer thinner sanded and started over it still messed up looked like oil on water. So I have sanded it down one more time washed throughly with lacquer thinner and will try again in the morning.
4/1/16       #9: refinishing cabinets ...
Robert Chickey Member
Try acetone. It flashes off significantly faster than lacquer thinner. You might ask your client what they were using to clean the cabinets. My guess is they haven't cleaned them and they are full of grease. Scrub them clean and then use acetone. Good luck.
4/1/16       #10: refinishing cabinets ...
Pat
Pre-Kleano and other similar products are a good choice because they contain multiple solvents that work on wax, grease and silicone. Trying to figure out what was used on a homeowner's cabinets is next to impossible.
4/1/16       #11: refinishing cabinets ...
Chris
Yes I did ask and she said she cleaned with pledge that's sorta what I had thought.
4/4/16       #12: refinishing cabinets ...
Bart
Try using a clear shellac based sealer. Then mist a couple of coats before laying it on heavier. Thin to win is the key.
4/22/16       #13: refinishing cabinets ...
jw
what you need to do is remove the contamination before you strip .
we never use remover until we wash the piece down with dirt tex and paper towels first , then strip away .
p s
sanding is not the way to remove a finish
hope this helps you
