Subject: Re: Ilva 710 wb
Ilva 710 wb
4/13/16
Joe Member
We have a customer that wants us to use this product. It's a paint grade cabinet job. Our local paint Store is not up on this so we have a kremlin 1014 or airless pumps would like to get any advice on tip size for both I tried a 13 thousands tip in the kremlin and have to really run up the pressure to max and use a lot of air to clean up the tails .want to know if ilva has a thinner for product other than water?any experience or advice will be most appreciated.
4/13/16       #2: Ilva 710 wb ...
chris
http://www.ics-ilva.com/ILVA-TechSheets/pw710series-techdata.pdf
4/13/16       #3: Ilva 710 wb ...
Joe Member
Any first hand experience? Thanks for the lonk.
4/14/16       #4: Ilva 710 wb ...
RobertJ
If using the Kremlin, you need to use their Waterborne tips. I believe they have a number '2' prefixed on their nomenclature.
Buy a couple, and keep them clean! IMHO waterborne is harder than solvent to keep them looking like new.
4/14/16       #5: Ilva 710 wb ...
chris
sorry Ive never used it but i use ILVA products all the time.
4/14/16       #6: Ilva 710 wb ...
Joe Member
Chris what ilva products wb or solvent ?I have used the two pac urathane really is to use but this wb seems like a good product just wanted some tip size info for aaa and airless and thinning recommendation.
4/15/16       #7: Ilva 710 wb ...
chris
only solvent base 2k urethane.
where are you getting it from?
4/22/16       #8: Ilva 710 wb ...
Joe
I'm getting it from Hirshfields a minnesota company what is a good tip size for this is pretty thick stuff any one .
4/22/16       #9: Ilva 710 wb ...
Joe
35 to 45 sec in ford 6 cup any recommendations?
4/23/16       #10: Ilva 710 wb ...
Joe
I'm thinking a 134-506-092 orifice is 11 K 9 inch fan this is their presence atomization tip recommended on their chart I want to have as much control as possible delivery rate hope with this size I won't have to thin much? Any one use this size with wb or the ilva 710 series ?
