Subject: Re: Pulling the trigger on a AAA rig
5/17/16
T Logan Member
Noted that this is probably just my hesitance to wright the check. But, I've narrowed my search down to 2 options. The choices- from what I've read as one of the Forum Favorites- The CAT OC14-P and also the cost efficient Titan MultiFinish 300. I'll be using it in shop on cabinets and furniture pieces shooting lacquer. Any input would be much appreciated.
5/18/16       #2: Pulling the trigger on a AAA rig ...
scott
I was just wondering how you came up with those 2? What is your budget?
I personally think the new Kremlin pumps are some of the best, they have 86 efficiency rate.
5/18/16       #3: Pulling the trigger on a AAA rig ...
kevin
i second AND third kremlin.
5/18/16       #4: Pulling the trigger on a AAA rig ...
Pat
I've had my CAT for almost 10 years and it's been virtually trouble-free. Made in the USA and customer support is the best. Easy to work on and it sprays beautifully. I spray waterborne and CAT's products have supported that longer and better than the other AAA vendors.
5/18/16       #5: Pulling the trigger on a AAA rig ...
T Logan Member
I'm looking to spend $3kish or less, I'm pretty frugal with the $$$. While Kremlin may be the best the only thing that moved me away from Kremlin was that I've read some people had serviceability issues. It's not really worth it to pay 20% more $ to get 2% more efficiency right now.
5/18/16       #6: Pulling the trigger on a AAA rig ...
Hen Bob Member
I am a fan of C.A.T pumps, the cost is half of a Kremlin. I do spray all solvent though.
5/18/16       #7: Pulling the trigger on a AAA rig ...
Hen Bob Member
Sorry I was incorrect on the $$$.
5/19/16       #8: Pulling the trigger on a AAA rig ...
JeffD
I have the CAT rig as well and have no real complaints with it. Only issue I've had in the four years I've owned it is the original seals started leaking, (apparently the post cat lacquers are pretty aggressive on seals), so I bought a new one and my rep came out and replaced it. The new ones are adjustable so should last a lot longer!
I was also looking at the Kremlin and would have gone that way but was about $1000 more than what the Cat was going for at that time, and CA Tech had a promotion going so I got a second gun free with my rig.
good luck,
JeffD
5/19/16       #9: Pulling the trigger on a AAA rig ...
What was said about service is very important. I have a CA technologies but there is no service anywhere close so when a seal went I had to go to a seal shop and see if the could find something similar, whereas the wholesaler here is a Binks and Kremlin dealer so that is why I use Kremlin. My Kremlin is 30:1 so I love it way more than my CAT anyways. I imagine it is just like buying a truck, everyone has their favorite.
