Subject: Re: fill between coats pimented varnish
6/6/16
greg zall
Website: http://gregzall.com
I am spraying black pigmented conversion varnish. I see the pro guys filling little flaws between coats with something paste like and then they sand it flush.
Anyone know what product?
6/6/16       #2: fill between coats pimented varnish ...
Wyatt
We use automotive spot putty for small defects. It comes in a toothpaste tube. The one we use is made by 3M.
6/6/16       #3: fill between coats pimented varnish ...
kevin
nitrostan spot glazing putty. available in different colors. similar to the 3m product but i tend to like it better
6/6/16       #4: fill between coats pimented varnish ...
Leo G
I use Mohawk Fil-Stiks. No dry time.
6/7/16       #5: fill between coats pimented varnish ...
Shane
I second 3m spot putty... I use the acryl green and the acryl white for the small defects.....I will normally use the green for contrast so my prep people can see the defect is fully sanded out flat and the white for... well white pigmented jobs so I don't have to worry about bleed through or the color not covering well
6/8/16       #6: fill between coats pimented varnish ...
Alan
Napa spot glazing putty #6390, light grey. https://www.napaonline.com/napa/en/p/MSR6390/
8/19/16       #7: fill between coats pimented varnish ...
james G
Pronto brand, " Kombi spot putty" . Real nice drys and sands like a champ..
Depends on wood and quality of wood your spraying , but It also helps to to put around 6-7 mils of primer down .Ml Campbell's Clawlock 2 . We do a tack/ wet coat first to release air trap in wood before we put down our wet coats on top of each other .
Besides nail holes splits etc ... Natural wood grain will be filled with just the primer. Sand crap out of it with 220 .....
