Subject: Re: Finish for finished risers and treads
6/10/16
Jeremy
Need some imput here. I have two flights of stairs to make and spray for a customer. The material will be red oak with a natural finish. I use gf enduro var for my natural oak cabinets, but I am wondering if this finish will be durable enough for years of heavy foot traffic. I have thought about using gf conversion varnish, but if the treads need to be refinished in ten years or so, will it be easy for someone to put a new coat on? I also thought about using a natural oil based stain and then using gf enduro poly as the top coat putting on four or five coats, but I'm not sure this is any more durable than enduro var. in my experience both products are similar in durability. Any suggestions or thoughts would be helpful. Thanks.
6/10/16       #2: Finish for finished risers and trea ...
Leo G
Use a waterborne floor finish.
Floor finish search
6/12/16       #3: Finish for finished risers and trea ...
+1 to Leo's recommendation. We started using Bona Traffic HD several years ago and never looked back. I have staircases that see daily use from entire families that I did when we first made the switch and its amazing how well they look today.
The Bona is a flooded finish and I have never seen any documentation on spraying but I have sprayed it several times. Its very thin. If you could simply lay out your treads and risers on the flat you could easily put the material on with an applicatior rather than spraying.
Mark
6/12/16       #4: Finish for finished risers and trea ...
Jeremy
Thanks for the responses. I did some looking at the bona hd and noticed it is waterbased and had a few questions. Does the product raise the grain like most wb finishes? On oak i usually sand to 220 to help with this problem. Second, does the bona give a nice golden hue to the oak or leave it rather pale? I like the gf enduro var because it has the tint in the finish, but maybe a light stain will be in order for the bona. Thanks
6/13/16       #5: Finish for finished risers and trea ...
peTe Anderson
Water-based finishes do not amber and loose the warm red glow that comes with solvent based finish.
You can stain with an oil or solvent based stain to get enough of a seal along with the color, or use an amber seal if you want the natural look. If you stain then it's not required to use amber seal.
6/13/16       #6: Finish for finished risers and trea ...
Leo G
Or you can put a couple drops of amber colored dye into the finish.
6/20/16       #7: Finish for finished risers and trea ...
John Member
No knowledge about Bona, but the WB topcoats I have used all raise the grain, and badly on red oak. I solve that problem as well as add some amber hue by applying a coat of Sealcoat shellac first. You can further adjust the color if desired by adding Transtint dye to the shellac.
John
6/22/16       #8: Finish for finished risers and trea ...
AaronV
Fabulon is a solvent based, very amber floor finish with a solid reputation. I've used it on many floors including my own.
