Subject: Re: Finish marquetry piece
12/5/16
Joel
Hi, I made three of these boards and I am wondering what you all would recommend for a finish. I was thinking shellac to fill the grain followed by a good wet coat of semi gloss pre cat. I am not looking to break the bank or spend hours on this. Shellac as a final topcoat is out as I have no idea what people are going to spill on them. Thanks for the advice...
View higher quality, full size image (2560 X 1536)
12/5/16       #2: Finish marquetry piece ...
Joel
I should add I am hesitant to go with a 'grain filler' like you get at woodcraft because the on time I tried it it didn't dry completely clear. Kind of a whitish color in the grain.
12/6/16       #3: Finish marquetry piece ...
RobertJ
Boiled Linseed oil to pop the grain. Then top coat with a solvent Post Cat Lacquer.
Let the Blo dry for at least 72 hours.
Or, you could just tung oil the hell out of it....
5 coats and wet sanding between coats. Need to wait 24 hours between coats.
12/6/16       #4: Finish marquetry piece ...
Dan cook
Nice work!
12/6/16       #5: Finish marquetry piece ...
Joel
Thanks Dan! I did a little online research and I ordered some crystalac. I'll do a test piece to be sure no problems. I would go out and buy a pro grade spraying system but it seems foolish to spend $150 just to finish three chess boards. I do mostly remodeling nowadays anyway.
12/7/16       #6: Finish marquetry piece ...
Charles Member
I agree. I have some marquetry and decorative veneering experience. That is very nice work, sir. :-)
