Subject: Re: finish for aromatic cedar
1/9/17
Js Woodshop Member
I'm making a hope chest for a customer that wants to use aromatic cedar for the floor. My concern, will the natural oil seep out of the cedar over the years into fabric that might be stored against the boards?
Thank you Jim
1/10/17       #2: finish for aromatic cedar ...
Yes, that is why the lids are aromatic - or lined with aromatic - more often than the floors.
Finishing the aromatic will stop the scent and the desired effect.
1/10/17       #3: finish for aromatic cedar ...
Js Woodshop Member
Thank you for confirming my concern.
1/10/17       #4: finish for aromatic cedar ...
I've lost count of how many blanket chests I've made with 3/8" thick kiln dried tongue and groove aromatic cedar lining. Both floors and sides. Never had an issue or call back in over 30 years.
1/10/17       #5: finish for aromatic cedar ...
I should have said 44 years. I just remembered I built one for my wife in the basement of our first home.
1/11/17       #6: finish for aromatic cedar ...
David R Sochar
As I recall, aromatic Cedar will 'set' the resins when dried properly, and this minimizes the possibility of staining. The commercial T&G is most likely dried properly, and certainly lends itself to use as rich mentions. The last couple I made, I cautioned the owners about the staining issue, and they both said they put things in a storage bag, then into the chest.
1/11/17       #7: finish for aromatic cedar ...
Js Woodshop Member
Thanks for your responses. It sounds like it's probably not a problem either way. To be safe I think I will seal and apply a finish to the aromatic cedar then cut 1/8" grooves maybe 3/8" apart. This would let the aroma escape but clothing would only touch the finished wood.
1/11/17       #8: finish for aromatic cedar ...
Be careful with that finish. Some solvent based finishes will off gas and smell for what seems like an eternity in a closed chest like that. Learned that decades ago on a small desk. You could smell the finish every time you pulled a drawer for at least 5 years. If you must, use a water based or shellac. Absolutely no solvent based!
1/11/17       #9: finish for aromatic cedar ...
Js Woodshop Member
Thanks for the heads up. I am planning using General Finishes water based Euro sanding sealer & Euro poly.
1/16/17       #10: finish for aromatic cedar ...
I recommend NOT finishing the cedar.
The main reason people want cedar lining is the nice aroma and moth repellence. Finishing will remove or greatly diminish that - even with grooves.
Also, the grooves will likely have splintery edges and even if sanded will be, IMHO, an unpleasant visual and tactile surface for pulling blanket and sweaters out of.
Save time, go traditional, and keep the customer happy - flat unfinished surface like grandma's is probably what they are expecting. I know I would be disappointed to find a finish on a part of a traditional furniture piece that almost never has one.
Don't overthink this - sometimes I try to solve problems that aren't really there!
