Subject: Re: Solvent
Solvent
1/12/17
Richard Member
Is there a solvent that will break down waterborne finishes? Particular something to soak spray guns in to clean the exterior.
1/12/17       #2: Solvent ...
Kevin Member
Acrastrip BG 600 is great. If you can get ML Campbell, they make a product called
GLC-10 that works as well.
1/13/17       #3: Solvent ...
Robert Member
I would think that any stripper would be sufficient to clean up the spray gun body.
The thicker type Jasco can be purchased at Homey Depot.
1/13/17       #4: Solvent ...
Denny J
Simple Green.
I use it in a parts washer and it does a great job. Use it at 10% solution and it will make them squeaky clean.
1/13/17       #5: Solvent ...
That's a wide open question. Lots of different water based formulations. I'd start with a lacquer thinner soak.
1/13/17       #6: Solvent ...
Denny J
I have used a myriad of different WB products and haven't found one that simple Green doesn't work in. Possibly the 2k wbs might not but anything else it's good to go. Plus it's got low toxicity.
I do know that one if the first WB finishes I used, the manufacturer had a solution that was primarily IPA and acetone. It worked well too but was significantly more costly than simple Green.
1/13/17       #7: Solvent ...
Richard Member
Thanks everyone.
rich c......specifically General High performance Poly.
1/13/17       #8: Solvent ...
Denny J
I use GF products all the time. It will work perfect.
1/14/17       #9: Solvent ...
Robert Member
I tried like heck to get along with Simple Green but for me, the smell was overbearing and lingered to the point that it made me nauseous.
1/14/17       #10: Solvent ...
Richard Member
"I tried like heck to get along with Simple Green but for me, the smell was overbearing and lingered to the point that it made me nauseous."
Not a problem for me. I've been using Simple Green for other cleaning purposes for many years.
Thanks to all for your responses.
