Subject: Re: Faceframes movement
Faceframes movement
3/30/17
Ryan Member
Hi, we prefinish our faceframes and attach them to our boxes with biscuits and pocket hope screws, we also pocket hope screw our faceframes. We use a lot of glue, let them dry for two days, then attach them, still I have small movement in the joint leaving barely noticeable hairline cracks at the joint, does anyone else have a solution to this ? I really don't want to attach them to the box raw sand tape and finish, does anybody else attach finish faceframes with success and no spider cracks at the joint, what's your process, or if you had the problem how did you fix it
3/30/17       #2: Faceframes movement ...
We use two pocket screws per face frame joint plenty of glue. Glue and pocket screw the frames to the box. Never have any joint cracking. That includes beaded faceframes with integral bead(not applied).
I'm going to guess that the biscuits are putting pressure on the frame and you are forcing down with the screws and/or clamps. Skip the biscuits. Use a couple of case clamps to hold the frame to the box until you get a few screws in it.
3/30/17       #3: Faceframes movement ...
mike Member
I'm not sure if you mean movement in the face frame joint or the frame to cabinet joint but if your face frame joint is moving try using epoxy; i do and never have a problem.
3/30/17       #4: Faceframes movement ...
Pat
How soon after glue-up do you finish your face frames? Ideally, you should wait 7 days for the glue to fully cure and the wood to stop moving due to the moisture changes from the glue.
3/30/17       #5: Faceframes movement ...
Mike Fuson
Sounds like to me that either the moisture content in the wood is to high, or humidity issues.
3/31/17       #6: Faceframes movement ...
Waiting 7 days and using epoxy are both overkill. Regardless of weather unless its raining inside your shop, pva glue will dry rock hard overnight. When glueing cherry, maple, oak, poplar yu can easily glue frames up in the morning and fasten them to the boxes in the afternoon without opening the joints.
It is easy to biscuit a stick of wood and a sheet of plywood. They will align. However, you are attempting to biscuit four sticks of wood in a frame to a box made of plywood. That requires a high level of accuracy. If one of the biscuits or one side is out of alignment by 1mm the frame must grow 1mm in width. Bam! the joint opens.
Just glueing the framing to the box is more than enough strength. No real need for pocketscrews, nails, biscuits. Just clamp and glue. We use pocketscrews so we can put together a pile of boxes using one set of clamps. The screws hold it together until the glue drys.
If you like how the biscuits align the frame to the box. Why not put them in the top and bottom rail. Putting them in the stiles may be whats opening your joints.
