Subject: Re: Respirator
Respirator
4/21/17
Manu Member
Good morning all,
We are spraying lacquer and pigmented lacquer and we use half face respirators.
The current one I am using is a C.A Tech.
My question is: based on your experience,
what kind of respirator are you using (half or full face),and what brand is best for you?
4/21/17       #2: Respirator ...
kevin
3m half face
4/21/17       #3: Respirator ...
herb johnson
a lot depends on choice of style
they are pretty much all the same cartridges that are noish approved
good luck
herb j
frankly i use a fresh air belt system when spray 2k poly and urethanes
4/21/17       #4: Respirator ...
Bart
You should have both. If you're doing a piece with no bounce back use the half and a full for inside cabs etc...Your eyes will appreciate the full face. Also store your respirators in a sealed container. This will extend the life of the charcoal filters which literally only last a week or two max if used daily.
These days I mostly just use a 3M N95 upgraded dust mask for spraying WB in my booth. Another benefit of spraying WB finishes.
4/21/17       #5: Respirator ...
chris
i Use a 3M supplied air system. Yes I'm spraying 2K urethane but i also feel less restricted in the hood system.
Also provides a cool air flow which is great in warmer weather.
4/24/17       #6: Respirator ...
al
Bart,
How do you know the dust mask is ok for spraying water WB finishes? They certainly would be more comfortable
but I thought you needed a respirator for any type finish.
Thanks,
Al
4/24/17       #7: Respirator ...
Manu Member
Thanks everyone for your response.
I will definitely try a full face.
4/25/17       #8: Respirator ...
Bart
Al, basically looking to stop particulate matter with the upgraded dust masks which do a great job of (that's why you have a pre-filter on your charcoal cartridiges). No solvent carriers or nasty catalysts in the GF products I use. If I was using a 2K WB I would definitely use a respirator.
