Subject: Re: walnut stain
walnut stain
4/22/17
stacoll  Member
I am trying to achieve this look for some walnut cabinets. I have tried several sample boards and cant get it. I tried wiping stains, dye stains and combos of both. Am I over thinking this? Any suggestions would be appriciacted
View higher quality, full size image (556 X 620)
4/22/17       #2: walnut stain ...
Robert Member
Website: http://bespoke-finish
Is the walnut natural or has it been steamed?
4/22/17       #3: walnut stain ...
Robert Member
More than likely you will need to apply a dye to the walnut to push it in the direction you need. Then apply a toner to get the right value and hue.
4/22/17       #4: walnut stain ...
Leo G
Looks like MLC American Walnut on walnut. Dull or Dead flat sheen.
4/23/17       #5: walnut stain ...
Alan  Member
You could try adding a little white to the stain, but too much white will block the pores. I made a stain similar to that once, for walnut.. It was super thin, like 90% solvent, and I want to think it was a little van duke brown and a little white, but it's been a long time, and I can't remember. You might have to bleach it first with a part A part B wood bleach, which would be a drag.
4/23/17       #6: walnut stain ...
RobertJ
I see some sap wood in the walnut panels. And it appears to have a slight shift in color, indicating a dye stain was used, not a pigmented stain. If your Walnut has sap wood areas, you want to be able to control its color in relationship to the linear grain of the walnut. Leo may be right about ML Campbell's Walnut stain, because it is a light bodied stain, but I would try using a heavily diluted walnut dye first. Hope you have success.
4/23/17       #7: walnut stain ...
Leo G
This is MLC American Walnut on walnut. The stain was diluted with their clear stain base about 50%. It has a satin 2K poly on it, you need at least a dull if not a dead flat. Plus I think I snapped the shot while it was still wet.
View larger image
4/23/17       #8: walnut stain ...
Bart
Black Walnut can naturally be that dark. I just did live edge Black Walnut table that is even darker with just super clear epoxy. If you're gonna use the usual kiln dried "purpleish" walnut then just about any brownish dye would get you there. A mix of GF's brown dyes would do the job. Start with a base of light brown and add in the med and dark browns to get where you want be. This seems pretty low on difficulty scale.
4/23/17       #9: walnut stain ...
That looks lighter than the usual walnut I buy. You might have to bleach it and then bring it back to the color you want. That's IF you have to use walnut. Butternut would be much easier.
4/24/17       #10: walnut stain ...
Bob Niemeyer  Member
Before I can even start to recommend anything I need to see a photo of your substrate(wet) next to your sample. Then we can go from there.......
