Subject: Re: Kremlin- rexson pumps
5/11/17
David Johnson
I have kemlin-rexson airmix pumps at 15-c25 and 30-c25. The manual calls for ptfe grease, graphite grease, lock rite 222, and lock tire 577 for maitanance uses. I am having difficulty determining exactly what these products are (I do not want to use wrong stuff that could result in finish problems like fisheye) as there seem to be a wide variety of products using these names. Also having troubles finding products to purchase. Manufacturer prices are astronomical. Any help would be appreciated.
5/11/17       #3: Kremlin- rexson pumps ...
herb johnson
okay if you are rebuilding the lower section of either pump, you can use a mineral oil for lubricantion, they loctite imho is not needed for attaching the pump piston to the pump piston rod, for the orings that secure the lower to tie rod part where the cartridge is , just use plain mineral oil which is pretty much inert, when you replace the throat packing be sure to insert the piston rod from the top thru the bottom of the cartridge do not go the other way, i learned the hard way and put the rod the first time up thru the bottom of the packing and ruined it,
and yes while great eqpt, kremlin parts are higher than most any competitor
good luck
herb j
5/11/17       #4: Kremlin- rexson pumps ...
kevin
call the rep that sold you the pump. They should stock all of that stuff for you.
5/12/17       #5: Kremlin- rexson pumps ...
Thomas
OP said "manufactures prices are astronomical"! Why share redundant information? it's obvious he is asking for advice regarding "generic" alternatives. lol
5/13/17       #6: Kremlin- rexson pumps ...
David Johnson
Hi Herb, Thank you for the response. You reccomend mineral oil for lubricant but which lubricant are you refering to, the graphite greaese (very expensive) for the metal parts, it seems mineral oil would evaporate much to quickly, or the ptfe grease for the o-rings. The Rep is trying to get info from the company but they of course want you to buy from them, I am looking for alternative products but unclear on what the graphite grease is. There is a multitude of products that claim they are graphite but most are dry lubes or mixes. I suspect I need 100% graphite which explains the cost. Also I must admit I have no real idea if such even exists.
As for ptfe grease the Rep says I can use pure 100% vaseline. The purity is highly important here.
The Locktite products (222 and 577) are refered to as low strength and medium strength respectively. I can not find these product numbers specifically in stores but I think I can just use low and medium strengths regardless of number (ie. Lowes carries 242 as opposed to 222, etc.).
5/14/17       #8: Kremlin- rexson pumps ...
chris
just checked on amazon. they have loctite 222. considering how little you will use just go with what kremlin has.
i know they are expensive but it will be the right stuff.
just rebuilt a grace pump. manual said to use grease. no more information.
yes i have 2 kremlins too.
5/14/17       #9: Kremlin- rexson pumps ...
Bruce Member
Hello I use Magnalube-G Ptfe grease. It can be ordered from Magnalube in 1 lb cans for $9.99. This is what Kremlin uses and is lube for the pump seals, Orings and Kremlin Xcite gun
Magnalube
5/15/17       #10: Kremlin- rexson pumps ...
herb
remember you are not greasing the pump for a lifetime, you only need enough mineral to lubricate the orings, and to slide the piston rod thru the packing one time, the lube is for assembly purposes only not for overall lubrication for the pump, if you are worried about the mineral oils "pureness" i guess that is a word, buy food grade mineral oil as pure as you can get
as far as loctite, you could use a blue loctite in a small bottle, the piston shaft to piston has virtually no side to side torque due to the cup being right against the cylinder wall
like i said just tryhing to save you a few bucks
good luck
herb j
