Subject: Re: Exterior Door
Exterior Door
5/24/17
Todd
I have been asked to refinish an exterior flat panel wood door. The client wants a red gloss "like a red sports car". Any suggestions on what product would be appropriate for an exterior red gloss finish?
5/24/17       #2: Exterior Door ...
Paul Snyder  Member
Website: finishing.tips
An acrylic catalyzed polyurethane (2K PU) is the best choice for a glossy finish in exterior use - it has the best overall durability properties. Once the door is stripped, I'd use an epoxy primer followed with a couple coats of red gloss 2K PU.
One brand that has worked extremely well for me is Matthews Paint - it's an exterior catalyzed acrylic polyurethane and they also have a complete line of primers for a wide variety of substrates. See the link below for a chart on their primers.
Matthews exterior catalyzed polyurethane
5/25/17       #3: Exterior Door ...
I had a customer years ago that wanted everything to look like an automotive finish. I used MDF, and sent him to the top body shop. We met there among a Lamborghini, a Rolls and a Ferrarri, plus the usual BMWs and Corvettes. They worked it out, and he was delighted.
Used the Italian flat color coats, then a gloss coat on top.
6/2/17       #4: Exterior Door ...
rfchickey Member
I may be in the minority here but look at Fine Paints of Europe. This is a European coating and the pigments that are used are far superior to anything available in the US. They have Hollandlac which is oil based and they have the ECO line which is a hybrid. This is an expensive product but you can brush it or spray it. The final result will blow your clients mind.
http://www.finepaintsofeurope.com
