Subject: Re: 3M respirator filter for Conversion varnish
8/11/17
al
What respirator cartridge # and pre -filter do most use when spraying conversion varnish?
Thanks,
Al
8/11/17       #2: 3M respirator filter for Conversion ...
Leo G
3M™ Organic Vapor/Acid Gas Cartridge 6003
8/12/17       #3: 3M respirator filter for Conversion ...
Mastercabman
What Leo said!
Also when not using
put the respirator
in a Ziploc bag or sealed container
Once you open the filters package
They are constantly working
8/12/17       #4: 3M respirator filter for Conversion ...
Bart
Absolutely keep them in a sealed container. Technically the charcoal is good for a few months depending on concentration of fumes. Back in the day making surfboards for a living when I lived in a respirator for hours a day I switched out 2-3X a month. The particulate filter once a month. I hope you're using a full face mask with the CV.
my2cts
8/12/17       #5: 3M respirator filter for Conversion ...
Leo G
Pretty sure a pair of cartridges are good for about 8-10 hours of heavy concentrated use. In the sprayroom with a fan taking a good portion of the fumes away from you they will last longer.
I would think that you should change them at least weekly.
8/12/17       #6: 3M respirator filter for Conversion ...
chris
get yourself a supplied air system.
8/12/17       #7: 3M respirator filter for Conversion ...
al
Chris,
What brand of supplied air system do you have? I am considering one.
8/13/17       #9: 3M respirator filter for Conversion ...
chris
I have a 3m versaflow system
very comfortable. also supplies coool air which is great in summer.
make sure you get a supply air hose which is made for supplied air not just a regular hose.
8/13/17       #10: 3M respirator filter for Conversion ...
Bart
General rule of thumb is 40hrs of usage or one month for most respirators at high concentrations. An hour here and there spraying with a good exhaust system is not to taxing an environment. High humidity can really affect the filter life in a negative way.
my2cts
8/13/17       #11: 3M respirator filter for Conversion ...
Go to the grocery store and buy one of those newer plastic food containers that have the silicone gaskets. I have one big enough the whole half mask with the filters attached goes in. The plastic bag idea with filters never works out well.
8/14/17       #12: 3M respirator filter for Conversion ...
al
Chris,
Do you have the battery one with filter you put on your belt or air from a compressor
with no filter? I can only find Versaflow with battery setup and not from compressor.
8/14/17       #13: 3M respirator filter for Conversion ...
chris
i have the one hooked up to my compressor
3m versaflo SA-100-PSK.
8/14/17       #14: 3M respirator filter for Conversion ...
al
Ok found it. If using your shop compressor is there a special filter that keeps impurities out
of breathing tube?
8/15/17       #15: 3M respirator filter for Conversion ...
chris
i have 2 filters inline and a water separator.
8/16/17       #16: 3M respirator filter for Conversion ...
DannyB
Note that 3M now has a cartridge with an indicator to tell you when to replace it.
If you aren't going to use supplied air, it's definitely worth it
8/16/17       #17: 3M respirator filter for Conversion ...
al
Info seems to be a little scarce on the supplied air systems. The one Chris uses is I believe called high
pressure system because he is using his shop compressor. I can't find enough info but I think the high pressure system requires quite a bit of cfm to operate it. The low pressure systems use a little compressor just for the breathing apparatus and nothing else. I've been on 3m website and a company called Allegro, Allegro sells complete system with the small compressor while it looks like 3m just sells
the mask, hoses, etc.
8/16/17       #18: 3M respirator filter for Conversion ...
chris
give Northern safety a call at 800 922 8553.
their technical support dept. can help you decide.
8/16/17       #19: 3M respirator filter for Conversion ...
CraigM
I use the Allegro half mask system. The compressor has held up well, but I have had to replace the straps on the mask a few times.
Allegro Safety
8/17/17       #20: 3M respirator filter for Conversion ...
DannyB
For the high pressure systems, you have a couple options.
1. They make portable boxes that provide everything you need. http://www.airsystems.com/index.php/2009-03-24-20-38-35/breather-box
2. You can go with a non-portable filter set.
http://www.airsystems.com/index.php/2009-03-24-20-38-35/air-panels
(these are just examples, 3m makes one, etc).
As someone else said, allegro (and others) make portable breathing pumps. These are just oilless rotary vane pumps from gast with the right set of filters and adapters (but, in my limited experience, you can't really get them cheaper from gast than allegro is selling them :P)
Allegro sells face masks that go with them, but they can also be made compatible with others.
For example, i found the allegro facemask to be a bit annoying. 3m makes a low pressure (and high pressure) breathing adapter for their half and full mask respirators.
http://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-Dual-Ai
rline-Back-Mounted-Adapter-Kit-SA-2000LP-Low-Pressure-1-EA-Case?N=5002385+3294780
269&rt=rud
(they have front mounted too)
These are attached where the cartridges normally go, in the same way.
I use an allegro pump with 3m masks and am quite happy with this set up.
8/17/17       #21: 3M respirator filter for Conversion ...
Richard
For those that use the Allegro half mask system, or similar how do you deal with the hose?
I always found it to be the weak link of the system, heavy and not very flexible. It makes me feel like I'm on leash.
I would love to find one that allows me to attach it from the ceiling allowing easier movement around the spray room.
8/18/17       #22: 3M respirator filter for Conversion ...
ColorPro Member
I cant stand using full masks tbh, they really get in the way.
I use a binks millennium 3000 with organic vapors cartridges and R95 particulate pre filters.
I use the cartridges till I begin to smell vapor and then change em out...2-3 months. pre filters I change out when they get dirty.
mask is light, comfy and have used em fpr 10 or so years
8/19/17       #23: 3M respirator filter for Conversion ...
DannyB Member
Richard,
You can use any hose you like, you just want to use things that ideally are rated for breathing air. They just give one that is cheap and effective (being rubber) :)
It also depends how much you are willing to spend.
You could easily just run a copper drop to the ceiling and suspend the hose from there.
You can also find plenty of very flexible scuba hose that is rated for breathing you can use (though sadly, miflex no longer does custom lengths).
