Subject: Re: Purple Stain
Purple Stain
8/16/17
Kevin Member
Trying to come up with a purple stain on maple. Customer would like it to match (or get close to) a Ben. Moore color that they like. Two suppliers I have talked to said this is difficult at best. I would prefer spray only, but I think this is even harder. Anybody out there have suggestions? We are now talking about a purple toner or shading additive that can be added to clear cv.
8/16/17       #2: Purple Stain ...
Jared Emery
If you have an ML Campbell dealer, ask if they have any red microtone dye (WS2M307). You can start there to mix up your purple. I used some a few weeks back and ended up spraying it over 3 coats of thinned vinyl sealer sanded to 320. When the dye sprayed out it went on opaque, which was kind of startling, but immediately turned transparent when clear CV went on over it. Strange, but the results were pretty darned good. The clarity was exceptional compared to a wiping stain, and adding a little dye to some thinned CV let us tone where we needed to.
8/16/17       #3: Purple Stain ...
Kevin Member
Thanks. I'll talk to campbell about it. A dye is probably more what I'm after. Lots of clarity. I see trans tint makes a purple. Maybe I can go from there.
8/16/17       #4: Purple Stain ...
Shane
Why not just experiment with Mohawk red dye and blue dye? carefully measure by part size and come up with a formula and spray directly to the wood till you get the intensity needed.... you will have the best clarity in this scenario....You should be able to get a bright purple color this way on maple..
8/16/17       #5: Purple Stain ...
chris
check out WD Lockwood stains.
8/17/17       #6: Purple Stain ...
Kevin Member
Thanks. I am having a woodsong spray and wipe stain made up and have ordered some lockwood dyes to experiment with. I have worked with dyes and toners before, but never used dye only under a topcoat. How concerned should I be about the color fading? There will be a good bit of light in this kitchen.
8/17/17       #7: Purple Stain ...
Bart
I used Lockwood for years but they do fade fast if there is any kinda direct light on them. I switched to GF dyes which are metalized for fade resistance. Most of the major brands of NGR's are metalizied. They still fade but last much longer than Lockwood.
8/17/17       #8: Purple Stain ...
Dan/drbwoodworks
We just had a weird Ben Moore dark blue matched in a MLC amazing stain spray only , they also did some crazy almost fluorescent colors too , we've never had a color they couldn't match stain or lacquer
8/17/17       #9: Purple Stain ...
Dan/drbwoodworks
8/18/17       #10: Purple Stain ...
Dan/drbwoodworks
8/18/17       #11: Purple Stain ...
Kevin Member
Man, thats frustrating. I was essentially told it couldn't be done. Not creating a purple color so much, but matching one from a paint chip. And the spray stain would be ideal. As for dyes, the lockwood dyes I ordered are metal complex dyes, supposedly more lightfast, but not still not sure if I should use them on their own due to fading.
12/29/17       #12: Purple Stain ...
seidoww Member
What Shane said...
Buy some Mohawk Blue and Red penetrating stain. And get some of the reducer for it also. Then start measuring and working the colors until you get what you're looking for.
Stuff works great and doesn't fade out like the WD Lockwood pigments.
