Subject: Re: Fixing defects in low sheen 2k poly
10/16/17
Brian Member
I'm spraying a 4 x 11 foot high figured walnut table top.
I have the top sealed with Ilva TA44 clear sealer, sanded to 320.
When I spray the 15 degree TS series Ilva and if I have a defect, how do I fix it? Once I touch it with any grit sand paper, it will affect the sheen. Then I have to recoat. Is this the only way to fix defects with low sheen topcoats, like a bug, or nib?
I have sprayed Ilve 5 degree TS Series on smaller tables with no issues. I had some overspray in an area and lightly hand sanded with 2000 grit to smooth it out and that worked fine.
Maybe I'm to picky and want a perfect finish and don't know when to stop.
How can I smooth out a dull area, or nib in a 15 degree finish without re-coating?
If I put to much low sheen finish on, more than 2 coats, will it look milky?
Ilva TA 44 Clear sealer
TX 75 hardner - TZ13 thinner
Ilva TS0005 acrylic clear topcoat
I have a short video of the top with the sealer applied, before sanding with 320.
video of top with sealer
10/16/17       #2: Fixing defects in low sheen 2k poly ...
I hardly ever ship something right off the gun. I'm a big fan of Abralon pads on a random orbit sander after flattening with 600 grit paper.
10/16/17       #3: Fixing defects in low sheen 2k poly ...
Rick Mosher
I always used a Konig KO163 metal planer as a nib file on low sheen tops. (Streck nib files will work also but don't have the weight of the Konig)
It will knock the sharp tops off the nibs and make the finish feel perfectly smooth without changing the sheen. Just use the weight of the file or you will leave a mark on the surface. (This is done using the sense of feel only)
Low sheen tops always end up a higher sheen due to cleaning people rubbing them down month after month. Don't lose too much sleep over it. :)
KO 163 Metal Planer
10/17/17       #4: Fixing defects in low sheen 2k poly ...
dar
you could also try a single edge razor, make sure you hone it on a 2000 stone first, I send almost all of my stuff off the gun, rubbing out is so risky and time consuming. what type of spray equipment are you using?
10/17/17       #5: Fixing defects in low sheen 2k poly ...
the google
you might also try plastic razor blades (like a single sided but totally plastic). it is hard to cause damage with one of these. we let stuff go off the gun as a necessity since we're not doing full grain fills.
i'm assuming you're using paper for a final rub down? it definitely helps and is also hard to screw up.
