Subject: Re: Pail warmers for water based?
11/22/17
Jonathan Mahnken
Was wondering if anyone is using pail warmers for their five gallon buckets and pressure pots? If so what type/brand do you prefer?
11/23/17       #2: Pail warmers for water based? ...
Steve Member
I’ve messed around with different ideas and finally just stuck a small magnetic block heater ( for cars) to the bottom of our 1 gal pails. It works well and is only about $30.
11/25/17       #3: Pail warmers for water based? ...
Pat
I haven't used one, but Graco makes a heater for this purpose.
Graco
11/27/17       #4: Pail warmers for water based? ...
Jonathan Mahnken
Thanks pat, I have seen those, they look pricey! I was hoping for a more low tech solution. And thanks steve for the suggestion, but most of my pails are plastic so I dont know if the magnetic feature would be my best bet. but the price is right in there with other pail warmers I have seen. My largest question is what temp range of heater should i buy? a few of them have a base temp of 86deg, is that too high? will warming waterbased too much cause it to kick? what is the optimum temperature for most waterbased materials?
11/27/17       #5: Pail warmers for water based? ...
Pat
LOL, they cost almost as much as my entire spray rig. At that price, I'll bring my pails home at night to keep them warm.
Cheers,
Pat
11/28/17       #6: Pail warmers for water based? ...
nicko
I thought i read once that someone was using a heating pad wrapped around there gallon cans of finish.
nicko
12/1/17       #7: Pail warmers for water based? ...
jbateman Member
There are rigid pet heater panels available from Lectro-Kennel that don't cost too much. They use about a lighbulbs worth of electricity. Set the pails on top of it, or some cardboard between the two if it's getting too warm.
12/7/17       #8: Pail warmers for water based? ...
Marco Silva
I've seen the one on the link bellow, but i use a fluid heater(kremlin) sometimes there are good deals on used fluid heaters like the kremlin or the wiwa, pretty much any fluid heater can work as a one pass without safety concerns.
http://goldspray.com/familias/prensas/calentadores/resistencia-calefa
ctor-cinturon-abrigo-flexible-silicona-25l.html
