Subject: Re: 2k urethane
2k urethane
12/11/17
Longarm Member
We are finishing a walnut bar top and are using sherwin Williams 2k urethane we have no experience with. It is about the consistency of pancake syrup and part b hardener much more liquid. We feel this is too thick to spray unless thinned. We tried a foam roller but finish has a orange peal effect. The trial is on bottom side of table so no damage to finish yet. Will second coat smooth finish out? Any ideas.
12/11/17       #2: 2k urethane ...
What are you spraying the 2K with?
12/11/17       #4: 2k urethane ...
Longarm Member
We would like to spray with a cup gun.
12/11/17       #5: 2k urethane ...
Then you'll have to thin it appropriately.
I tried spraying MLC Polarion with a HVLP and I didn't get great results. I switched over to my AAA and it works great. Just have to make sure you have plenty of thinner to clean out the AAA pump. And make sure you get it out of the pump before it kicks off, or you'll have a big mess on your hands.
A pressure pot would be my next choice after the AAA.
12/12/17       #6: 2k urethane ...
Bob Niemeyer  Member
SW should have TDS on the product. 2k PU's are known for their flow.
You can use a cup gun, just have a needle/fluid nozzle of 1.8mm. Also you need to apply very close to 4 mill per coat to get good flow out.
Most PU's have a separate sealer and topcoats and many will also have an Isolante.
I use ICA PU's and have excellent results.
ICA Wood Coatings
