Subject: Re: Bubbles in finish
Bubbles in finish
1/22/18
Jacob Member
Lately I have been having problems with my clears. I currently use ML Campbell product.
I use magnasand for my sealer and Magnamax satin or Magnaklear satin for my top coat.
In the past couple of weeks I've been having a problem with air bubbles not escaping the top coat and drying in the finish, causing dried hard bubbles.
I use a compressor fed airline to a Devilbiss FinishLine FGL4 HVLP gun regulated down to 30psi for most situations.
Only thing that seemed to help so far was thin the heck out of the top coat with Reducer/Retarder and thinner enough to be sprayed at a 15psi pressure at the gun. Taking forever at that pressure.
Any tips?
I'm finishing cabinet doors, parts, accesories, etc.
Thanks for any advice.
I attached a picture. Hopefully it's not too blurry.
View higher quality, full size image (524 X 591)
1/23/18       #3: Bubbles in finish ...
Bill  Member
Website: canadianacabinets.com
I have to ask how are you drying? Is there a direct heat source near the work.
1/23/18       #4: Bubbles in finish ...
Shane
Textbook solvent pop.....
your coating is skinning over too quickly.... if you want to solve it look into adding butyl cellosolve at 3%....I think ml cambells flow enhancer at 10% should do the job also... its going to affect your overall cure time but it will sure help the finish lay out better..... you either have too much draft of air moving across the panels or a heat source...
1/23/18       #5: Bubbles in finish ...
Jacob Member
So before I got a chance to read your responses, I was in contact with my Campbell rep. He suggested that I lower my pressure down to 15psi. I was spraying at 30psi.
It took forever and I had to thin the material down but it did help. However, since I had to thin the material so much to spray well enough at that PSI, the quality of the final dry finish was weak.
As to the heat source I shut the heat off while spraying to try to prevent too fast of drying or random particulates being thrown around the air while the pieces are drying.
I was using Campbell's Retarder/Reducer. I'm not sure without looking at the can again that it's chemical you suggested.
On a side note, that same rep that was helping me out, brought out a AAA system to demo and we ended up finishing up an entire job with it. Wow. What a system. I have been missing out. I cannot believe the transfer efficiency. Now I just need to be able to afford this system.
I had no bubble issues with using the AAA system either.
Thank you guys for the helpful responses. Much appreciated!
2/16/18       #6: Bubbles in finish ...
Duane
Yes could certainly be solvent pop but if you have ruled that out check to see you don't have water in the line that will do it also.
