Subject: Re: Rub through finish
Rub through finish
4/2/18
Dan
I'm doing a black with white top coat and rubbing through so the black peaks through the white. Question is do I need a clear top coat? I'm using mlcampbell CV.?
4/2/18       #2: Rub through finish ...
Robert Member
Couldn't hurt Dan. Is there a reason you cant make up a few different samples to see whats going to be the best route for your customer ?
4/2/18       #3: Rub through finish ...
Family Man
I've always found the clear coat necessary to hide the sanding scratches from rubbing back through.
4/3/18       #4: Rub through finish ...
Dan
Family man That's what I was thinking also.
Thanks.
4/3/18       #5: Rub through finish ...
Family Man
No problem. Glad to help. Have you thought about the black being a stain? It helps to 1) control mil thickness and 2) not rub through the black back to raw wood if you get a little heavy handed sanding
Good luck
4/3/18       #6: Rub through finish ...
JM
Ditto to what family man says. I would approach this as follows
Black prime
Clear sealer
White
Clear topcoat.
I would put the clear between the black and white to help with two things....1) so you dont sand through the black, 2) so the black is less likely to contaminate the white. We have also found using a card scraper is better than sandpaper for getting the rub-thru on edges.
4/3/18       #7: Rub through finish ...
Dan
Thx JM for the card scraper tip.
4/4/18       #8: Rub through finish ...
Dan
4/6/18       #9: Rub through finish ...
John Bishop  Member
Website: selectwoodworking.net
We always clear coat for protection I think it adds depth also. Easier to fix scratch in clear than paint.
Their process is spot on
