Subject: Re: Black stain and yellow glue
7/9/18
Stefano
I trying to tint on black the yellow glue to make it less visible in the joints under the black stain and I wonder if someone know if there is a way to make the yellow glue black. Thank you
Stefano
7/9/18       #2: Black stain and yellow glue ...
John Member
Black Transtint dye will make yellow glue black, but if your joints are tight there should be no need.
John
7/9/18       #3: Black stain and yellow glue ...
PVA yellow/white glue likes to have very thin essentially invisible glue lines.
If you want the glues lines to be visible I would use epoxy resin and tint it black. Epoxy prefers to have thicker glue lines.
7/9/18       #4: Black stain and yellow glue ...
Stefano
Thank you John, it work with Transtint. Actually I need the glue only for the splined corners because some tine, not so often, it happen that there is a very little gap and the tinted glue it help
7/11/18       #5: Black stain and yellow glue ...
Dustin Member
Website: http://www.rhodeshardwoodflooring.com
You can buy black glue sticks on Amazon. However, dyes will also color it black. Hope this helps.
