Subject: Re: electric airless pump with an AA gun. Possible?
9/3/18
Carl Howell
Trying to creat a portable site finishing rig. Considering if its possible to find the fittings and piece together a rig using a graco 395 pump for the fluid and a turbine unit for the atomizing air and run it through a kremlin excite gun.
This would provide several benefits over a portable compressor; more compact, lighter in weight, supply dry air all the time. The graco pump, obviously does not need compressed air.
I think the whole rig could be assembled into a single cart of some fashion.
Anyone have any experience or know of something like this?
9/3/18       #3: electric airless pump with an AA gu ...
Brewster201 Member
Hello I don't think it will work, you will need minimum 15-20# air pressure for the Kremlin Xcite gun to reduce tails. Maximum your turbine will output is 8-12# and finding fitting might be challenging
Just easier to add a small A/c with a dryer
9/3/18       #4: electric airless pump with an AA gu ...
Pat
CA Technologies makes a portable pump/compressor combo on a cart. (see "Portable Air Assist Airless 14:1" halfway down the page on the link below.) I've used my CAT AAA rig (not the combo) with a small cheap 2HP compressor to do site finishing and it worked fine. It was sufficient to power the pump and supply the atomizing air.
I'd think you could get away with a smaller compressor if you're using an electric pump. No idea if the different pump types are compatible with AAA guns, though. Is the 395 a diaphragm pump?
Cheers,
Pat
CAT AAA
9/3/18       #5: electric airless pump with an AA gu ...
Brewster201 Member
You really don't have spend big bucks to upgrade, all you require is a 4 cfm compressor and your good to go. The Xcite gun is excellent
9/3/18       #6: electric airless pump with an AA gu ...
I've used my 10:14 with a 1/2 HP compressor and a 5 gallon side saddle air tank. I was just doing small areas at a time and don't know how long I could go before the pressure went to low, but it worked fine.
9/4/18       #7: electric airless pump with an AA gu ...
nick
yes, you can.I did this for awhile before I bought a air motored powered pump. All you need is a smallish pump that will dial down to a medium low pressure without fluid pressure fluctuations (or a add on high pressure fluid regulator...these are expensive), a 1.5 or 2 hp air compressor, half way decent oil & h2o filters (you can skip the oil filter if you use a oil-less compressor), air line and a AAA gun that's capable of handling 3,000 psi, of course you won't be spraying at 3,000psi but to be on the safe side you will want a gun that can handle the max fluid pressure of your pump.
Now with that said if you purchase these items new you're around 1/2 to 1/3 the price of a new air motor powered AAA set-up and without a doubt a air motor powered AAA is a the way to go as you get way better control over fluid pressure especially at the low end and low fluid pressure means a lot less overspray. The point being it might be dollar wise to just pony up for a air powered pump from the get-go.
9/4/18       #8: electric airless pump with an AA gu ...
Brewster201 Member
Nick I think the original question was that he has a Graco paint pump and could he use a turbine to supply enough air to a Kremlin Xcite gun to make it a AAA setup
No he can't due to lack of psi from the turbine
9/10/18       #9: electric airless pump with an AA gu ...
Russell Isaac Member
Another thing to do is keep your eyes open for a Graco FinishPro 395. Electric airless pump mounted on a cart complete with the compressor, digital pump control and G40 AAA gun. Used to have one like that and it worked well. Weighed about 100 pounds.
Also, you could check out Graco's new low pressure fine finish tips. They work at lower pressure than the old fine finish tips... No tails at the lowest pressure I could set on a Graco 390... If that works, you save the hassle of a double hose to the gun as well as a compressor
