Subject: Re: Exterior primer
Exterior primer
9/7/18
Mark Member
Can anyone recommend an exterior primer that dries quickly and sands easily. It would be nice to find a WB primer that would fit the bill, but I've yet to find one that sands easily. Oil based primers all sand easily, but don't always dry quickly enough. I'd like to be able to fully sand the primer in 14 hours or less, but what I'm finding with oil based stuff, is they can take 30+ hours to really be able to sand properly, and be cured enough to paint over. I'm a sign maker, and I work with PVC and wood. Most of what I see is if I finish paint too quickly, even if it seems like the primer is dry, and it's over the amount of drying time given in the PDS, I have adhesion problems when I mask the final paint coats.
9/7/18       #2: Exterior primer ...
Tyler
Aquaprime by chemcraft.
Though not labeled as an exterior primer by the company, it was formulated for use on Windows, and I know several shops who have used it for exterior purposes for years with no issues.
Dry to sand in 40-60 minutes. Sands like a lacquer primer
9/7/18       #3: Exterior primer ...
Mark Member
Thanks Tyler.. Yep, that was one on my list to try. Man, if it dries that quick, it's going to be my new primer. Hopefully I can get it locally.
9/7/18       #4: Exterior primer ...
Tyler
Stuff is awesome. I spray mostly CV, but I keep a gallon of it in shop at all times if there's ever anything I off ball job. Has really minimal grain raising too. Very impressive WB
9/7/18       #5: Exterior primer ...
Mark Member
I ordered a gallon by mail order. On Monday, I'm going to try to run down a local supplier as well. I'll let you know how I make out. Sounds like what I've been looking for.
9/7/18       #6: Exterior primer ...
Tyler
Best of luck! Just strain it out or you'll be sorry
9/9/18       #7: Exterior primer ...
DeanV Member
Just be careful with any primer not specifically labeled for exteriors. We have run into problems with real exterior primers from prefinish shops. So, I would be really hesitant to trust a non-exterior primer. It sounds like a really bad idea to be honest.
9/20/18       #8: Exterior primer ...
Mark Member
Tyler, this primer is unbelievable so far! I have it on a test piece right now, putting it through worst case scenarios, and it's passed each test with flying colors. One test remains, and if it passes, I'm switching over to it. One thing is for sure at this point. For an interior primer, it's the best thing I've seen. I sprayed it and sanded it 4 hours later. It was as hard as a rock and sanded better than the oil based stuff I use. So, fingers crossed for the exterior stress test. I have high hopes. Thanks for the heads up!
9/20/18       #9: Exterior primer ...
Tyler Member
Happy to hear it! Everyone I know who has tried that stuff says the same exact thing. Fingers crossed on exterior stress test
