Subject: Re: WB stain for oak - white wood pore
9/12/18
mauricio poli Member
Hi fellows.
We are staining solid white oak chairs, and we are using a water based stain, a mediun brown.
We want to use only the spray gun, not wiping anymore, because it is a lot of chairs.
But we are having a problem tha we could not solve, in some parts of the chair we see the pore white. It happens because the stain cannot tint inside the pore.
What we can do to avoid using a wipping process ????, because today is what we have to solve the problem... but itīs a lot of time and material waste...
Any suggetion ?
Thanks a lot for any help
9/12/18       #2: WB stain for oak - white wood pore ...
CWWOODWORKING
How many chairs?
9/12/18       #3: WB stain for oak - white wood pore ...
250 daily
9/12/18       #4: WB stain for oak - white wood pore ...
Cwwoodworking
Not trying to sound like an a$$, but at that volume 63,000 chairs a yr, you should be able to tell your supplier to figure it out.
Ask for a technician to spend a couple days in your facility and bang out all problems.
9/12/18       #5: WB stain for oak - white wood pore ...
nick
I just finished 30 white oak tables with a black WB stain. I too only wanted to spray no wipe the stain and after doing this I too ended up with some unstained open grain spots. The fix i came up with was to wipe on and wipe off the tables with a stain saturated rag after sealing and sanding. This worked great and added no more than a hour to the job...That said; finishing (30) 2x4 tables in 2 days is not the same as 250 chairs a day...hopefully somebody has a faster fix for you!
9/12/18       #6: WB stain for oak - white wood pore ...
It's the surface tension of the material that prevents it from flowing into the pores. Only fix I know of is wiping.
9/13/18       #7: WB stain for oak - white wood pore ...
mastercabman Member
You could spray on and then wipe off!?
9/13/18       #8: WB stain for oak - white wood pore ...
Hello everybody !
We are spraying and wiping.
It is the only way we could find to have all done quickly and well done.
Thanks to all your time and attencion
9/14/18       #9: WB stain for oak - white wood pore ...
Larry Schweitzer
Just a thought, what happens if you add some alcohol to the stain? It would reduce the surface tension. Worth a try?
9/24/18       #10: WB stain for oak - white wood pore ...
edge3
all you need to do is decrease the surface tension of your WB stain.A little bit of detergent added to the stain such as a couple of drops of window cleaner per gallon of your stain will work...Give it a try.
If you have smelled the Arti Olesol stains from Italy you can detect the sleight odor of
Windex...Good luck
