Subject: Re: Dirty finish, That time of year again
10/23/18
Gary Member
Every year at about this time we experience fine dirt in our finish. It is most likely caused by lower humidity. We start using the heated air make-up system and running humidifiers but the humidity is still lower then in summer. It only seems to be a problem with conversion varnish. Pre-cat and vinyl sealer do not seem to be affected.
This year we are also experiencing some fish eye but I expect that to be a separate issue.
10/23/18       #2: Dirty finish, That time of year aga ...
Gary Member
Any idea's
10/23/18       #3: Dirty finish, That time of year aga ...
Sounds like a dirty air makeup unit. Are the filters clean and new?
10/24/18       #4: Dirty finish, That time of year aga ...
Steve
we spray conversion varnish also and are in the northern part of the country dry winters. I have had the same experience. We narrowed it down to humidity apparently CV has a higher static charge for some reason. We built a humidifier/mister. We bought some misting tips from a co. that makes misting fans that are used in dry climates and built a fan of our own. Small pump, misting tips, and a cheap box fan hung from the ceiling very inexpensive compared to premade systems and is effective the finish is much better since we started using it last year.
10/24/18       #5: Dirty finish, That time of year aga ...
If it's static electricity then spray your fist coat, scuff and then wipe down with denatured alcohol. That tends to kill the charge for a while.
10/24/18       #6: Dirty finish, That time of year aga ...
the google
is what you are experiencing constant for the winter months, or lasting a month or so while everything adjust to cooler temps and lower humidity?
i experienced the same last week shooting 2k poly. switching over to thinning, instead of retarding, seems to have addressed this problem for me.
10/24/18       #7: Dirty finish, That time of year aga ...
Gary
The problem mostly goes away after e few weeks. I do have a humidifier that hangs from the ceiling I will install in the finish area. Will also try the denatured alcohol. Google, are you saying your finish is drying faster now and that has helped?
10/24/18       #8: Dirty finish, That time of year aga ...
the google
gary,
the finish does dry a little faster but without bubbles/trash. mine might be unrelated to temps/humidity, but i have frequently experienced similar problems in the same times of year. switching to thinner does seem to help.
10/30/18       #9: Dirty finish, That time of year aga ...
Matt
Most likely the CV is flashing off while still floating in the air.
See if your CV is compatible with EEP or Naptha (my CV is, KemVar Plus) and use around 3-5% of either to help keep the film surface wetter just a bit longer to allow any overspray to settle into the film.
11/7/18       #10: Dirty finish, That time of year aga ...
mauricio poli Member
You could ask your CV coating sales representative for another catalyst or thinner. Maybe you have to change them during the seasons.
Why donīt you try water based material? It is easier to use.
Good luck
11/7/18       #11: Dirty finish, That time of year aga ...
Gary
Thanks for the responses. We added humidity and that seems to have taken care of the problem.
