Subject: Re: exterior finish failure
10/30/18
doug mclaren  Member
im in southwest fl. i usually use an exterior spar urethane on doors, but on a recent garden gate and arbor the finish fails in a year.
recoating lasts only about 6 months before it fails.
i m using sapele and african mahogany.
looks like driftwood after failure.
any suggestions besides paint?
10/31/18       #3: exterior finish failure ...
David R Sochar  Member
2 things:
All exterior finishes fail. What separates them is how the fail and how they accommodate the refinish. Sikkens is designed to fail and to accommodate the guy that has to recoat. Urethane has to be the worst when it fails.
Design of exterior work can help make it last longer. Flats as seen on the upper edge of your rails will allow water to sit and work into the panel/rail joint. End grain must be epoxy coated.
11/5/18       #4: exterior finish failure ...
The Cajun Craftsman Member
Most exterior finishes will fail to some degree. With that being said, there is a way to prolong it. We have been using this product for years doing the brightwork on boats. MultiWoodPrime It amazes me how well it works together with 2 part finishes. Essentially gluing the finish to the wood. We use Bristol Traditional clear finish over most of our work after priming with the CPES. We have used it as a base sealer for paints, varnishes and epoxy also. It's compatible with just about all finishes, be it water or solvent base. If you have questions, the owner, Steve Smith, will personally answer them for you. Good luck!
MultiWoodPrime
11/7/18       #5: exterior finish failure ...
mauricio poli Member
I would use a colored water based stain for exterior.
Color will help product to last longer than a clear material
Do not use materials that create film thickness on exterior wood products, it is very difficult to say if will last or not.
And sell a 6 month recoat service, a beautiful job like yours, do need somebody to take care of it. Congratulations!
11/9/18       #6: exterior finish failure ...
robert johnston
You may want to explore the use of a 'boat' finish, typically referred to as 'brightwork' and usually a high gloss finish.
Go to Jamestown Distributors for examples.
Epifanes and Awlgrip and Interlux all offer exterior coatings for wood.
11/9/18       #7: exterior finish failure ...
doug mclaren  Member
Used water based dye. Then oil based pigment. Then 3 coats thinned spar urethane with uv inhibitors .then 2 coats same.
Still looks like driftwood 1 year later.
Difficult to sand project assembled and in place.
Has anyone tried a light pressure clean to get back to original wood color before recoating ?
I have seen this done on exterior ipe successfully before reoiling with alkyd modified tung oil.
