Subject: Re: trim finish
trim finish
1/13/19
Scott Member
Website: http://durangopaintingcontractor.com
Hi I AM GETTING READY TO OPEN A PREFINISH SHOP FOR NEW DOORS, BASE, CASE,AND TRIM FOR NEW CONSTRUCTION PROJECTS. AS A PAINTING CONTRACTOR I have been charging 1.71 a ft. up to 6 inches wide for lacquer work doing pre sand, 2 coats of sealer and 1 coat of finish. Now that I am opening a shop with associated overhead. I am trying to get some pricing figured out.
1/13/19       #2: trim finish ...
If you were making an acceptable living at your current price, then just add all the new overhead. I don't see any need to mark up the overhead. Make sure you allow for some slow periods in that calculations. Just add up all the overhead, and divide by your anticipated billable hours.
1/14/19       #3: trim finish ...
I would agree with Rich that establishing your own pricing based on your overhead, materials, and labor, costs should be pretty straight forward to see if your competitive with anyone around you offering similar services. Being in the business Im sure your aware of all the legal and environmental issues that would apply to you (EPA, OSHA, State/local) running a finishing operation in your area.
Beyond that its just plugging the numbers into a spread sheet and check out the bottom line. You've probably got a pretty solid number that will fly given your already in the game.
