Subject: Re: 2k poly question
2k poly question
2/7/19
Kevin Member
I've been using the chemcraft verde line and really like it, clear only, never used pigmented. I'm wondering if a white 2k poly would resist the hairline cracks that occur time to time in door and face frame joints. I realize that this is a wood movement issue, but my thinking was poly is less brittle than cv, so maybe it would mitigate the cracks. Can anyone confirm this? Thanks.
2/7/19       #2: 2k poly question ...
mauricio poli Member
Hi ! Do not resist. It will crack the same way.
2/7/19       #3: 2k poly question ...
Tyler
while not a 100% fix, it DOES help. 2k Poly allows for about 10 mils of movement before it cracks, whereas CV allows only 3-6 mils of movement.
2/7/19       #4: 2k poly question ...
You should not be getting cracking. Fix that problem instead of trying to find some magic coating. If you use TiteBond 1 glue you will be much happier.
2/7/19       #5: 2k poly question ...
Jon Member
I don't get cracking at the FF joints, and use Titebond 1 (the old regular Titebond).
Does Titebond 2 make the finish more susceptible to cracking at the FF joints? Is that because it is softer and allows more movement?
2/8/19       #6: 2k poly question ...
Im with Jon. Im wondering if you have creep issue. What glue?
2/9/19       #7: 2k poly question ...
Kevin Member
I'm using titebond 1. Face frame cracks aren't really too common, but I outsource my paint grade doors, so I'm at the mercy of the manufacturer. I'm familiar with all the steps, plenty of glue, plenty of dry time etc, but it can still happen. It isn't sunken glue lines, its hairline cracks. Seems like cv is just a brittle finish. Winter months are worse for sure. Thanks for the responses.
