Subject: Re: latex paint drips on my vanity cabinet door
2/17/19
pat Member
The painter got a couple of drips on the new vanity we installed what is the best way to remove them I believe it is a lacquer finish but I could be wrong. they have been there maybe a week.
2/18/19       #2: latex paint drips on my vanity cabi ...
The best method I have found is to get the painter back to remove his drips. If you still owe them any money, that should get him there faster.
2/18/19       #3: latex paint drips on my vanity cabi ...
D Brown
There is a product called Goof Off that will work fine.
2/18/19       #4: latex paint drips on my vanity cabi ...
Matt
Agreed with the above but you have to be careful with Goof-off, I've seen it dissolve basic lacquer before.
The first response you got was the best, if these painters are paid contract painters, they are on the hook for anything they've boogered up like that.
If you are stuck doing this yourself, start with a dish rag, a drop of Dawn detergent, and hot water, and a gentle fingernail. Usually wall paint is simple enough to soften with hot water and gently fingernail it off.
2/18/19       #5: latex paint drips on my vanity cabi ...
pat Member
Unfortunately the painter is my wife. She does a great job always. This is one of those times where shit happens and something slipped by we are both very picky. I have not seen it yet but will be there tomorrow. I was thinking of trying to soften it up maybe with a blow dryer or will try the dawn with a damp rag and the maybe gently
scrape with the edge of a credit card ? Thanks for the responses any others would be much appreciated.
2/18/19       #6: latex paint drips on my vanity cabi ...
The sooner you remove it the better. Same day removal is easy, 2 weeks is tougher.
2/19/19       #7: latex paint drips on my vanity cabi ...
Denatured alcohol is aggressive on waterborne products. Use a dampened rag it will clog quickly so refold and continue to wipe.
2/27/19       #8: latex paint drips on my vanity cabi ...
mike j
Test a spot on a lower part of the vanity or the back of the door. Wipe some lacquer thinner on the spot. If the finish does not soften it is most likely some lacquer based finish as you suspect. The same cloth and lacquer thinner will clean off the latex paint without hurting the vanity finish, which is probably conversion varnish, the finish typically used in kitchen cabinet shops because of its quick drying, hardness and moisture resistance. Catalyzed conversion varnish will not soften with lacquer thinner.
2/28/19       #9: latex paint drips on my vanity cabi ...
DanShaf Member
If the finish is conversion varnish, or 2k urethane, or fully cured precat (min 3 weeks) then you can use a small amount of toluene on a rag. Xylene will also work, but not as effectively as tolune. By the way, Goof Off is xylene.
2/28/19       #10: latex paint drips on my vanity cabi ...
pat Member
Thanks for all the suggestions. I ended up putting a little dish soap on the drips and then held a hot damp rag on them for a minute. Then I took the edge of a credit card and gently scraped them of and they came off pretty easy !!!! Thanks again everyone.
