Subject: Re: Spray system
Spray system
3/13/19
Lukasz Member
Which spray system choose
KRemlin or Wagner
Any recommendations
We are small shop 7000sf
Mostly spraying solid colors we using now 2.8 Gallon Pressure Tank, with Dual Regulation
3/14/19       #2: Spray system ...
mike j
kremlin. It has kept me in the business for over 20 years. You will never want to touch a pressure pot ever again. The pressure pot is too heavy and too difficult to clean. A Kremlin will make your life better and make you money.
3/14/19       #3: Spray system ...
I have a Kremlin and it's been great for the most part. Keep it clean and it'll keep you in business.
Simple to work on for the most part. Take apart and put back together and back in operation in less than 1/2 hour if something gets clogged.
I've had mine for 12 years now and haven't done a rebuild. Doesn't seem to need one either. The gun might.
3/18/19       #4: Spray system ...
Shane
You should be running the kremlin 10:1 pump with a cart or wall mount with xcite gun and never look back...… a little more budget friendly would be the cat 15:1 unit.....cart mount or wall mount both are fine units and will be a major improvement in quality and ease of use/maintenance .
