Subject: Re: What size compressor?
3/16/19
Hello,
I was wondering what size compressor I would need to run a da and a hvlp cup gun? Not simultaneously. Also any suggestions for for best setups?
3/16/19       #2: What size compressor? ...
15 CFM minimum
3/17/19       #3: What size compressor? ...
herb johnson
somewhat depends on whether you have single or 3 phase
but buy the largest one you can afford, the slower the compressor runs the longer it lasts and the less heat it builds up,
be sure to look for a refrigerator dryer if in the budget.
for most hvlp guns you need 15-20 cfm unless you get a low cfm cap but most low cfm caps sometimes don't have the energy to give you good atomization, if you are running something like a dynabrade 5'' orbital i believe you are around 15cfm also
be sure to buy a paint grade air filtration system, not a cheap versions, will make your vanes in your sander last longer with less junk building up in the vanes, also less junk, oil etc coming thru you spray gun
good luck herb j
