Subject: Re: Touch ups on prefinished cabinet crown joint
3/23/19
Phil Member
Hi,
I have a splice joint on some 7" prefinished white cabinet crown that I installed last week that needs some love. I took a touch up stick to it and the joint is only visible under certain lighting but I'm still not super happy with it. I could take the pieces down and redo it, but I'm not convinced I'm going to be able to get it better than it is. It's a on a 16' run and the ceilings are relatively low so you do see the joint in reflected light. The clients are OK with it but I'd like if possible to make it disappear more.
What I'd like to do if possible is sand the joint a bit and then respray it.
I have touched up cabinet doors before by essentially repainting the entire thing but never just a small area.
Would it be possible to touch up just the area around the joint with a touch up gun or would I be best off respraying the entire run.
Thanks!
3/24/19       #2: Touch ups on prefinished cabinet cr ...
RichardP
Not enough info to give good advice.
You call this prefinished crown. Did you finish it? What is the finish. Spray what material inside a customer's home? What kind of touch up stick?
Success is making the customer happy, not stroking your own ego. I hope you answer my questions. I suggest leaving this alone.
Rich
3/24/19       #3: Touch ups on prefinished cabinet cr ...
Phil Member
Hi Rich ,
To answer your questions:
1) I did not finish it. It came from a large custom cabinet manufacturer so I believe it's a UV cured finish.
2) The touch up stick I used came with the cabinets, its a soft wax I think.
3) Looking for advice on what finish to spray. What I spray in the customers home depends on whether I can just touch up that small area or if I have to respray the entire run.
3/25/19       #4: Touch ups on prefinished cabinet cr ...
mike
I totally understand you wanting to get it better but i'd tread lightly with this. Once you sand it you are committed to a fix although worst case you just need to replace the crown. Last time I had this I called the company and got a supposedly matching aerosol can from them. Unfortunately the match was not good. I then had them send a 1/2 pint of the real thing pre- catalyzed and the match was good with a Prevail sprayer. You also may consider a Mohawk-finishing product like 'perfect blend' to blend in the sheen. Overall its just hard to get a perfect job-site repair on a sprayed finish.
3/25/19       #5: Touch ups on prefinished cabinet cr ...
Phil Member
Thanks Mike. I probably will leave the joint well enough alone since I don't really know what I'm doing , but I couldn't help playing around this weekend with some scraps and some tinted precat lacquer.
Seems like I could get the color and sheen to match up pretty well but I had difficulty where the new finish feathered into the old. There was a band of a rougher texture between the new and the old. Did you experience this with the Prevail? Is it something I'm doing wrong or is it just the nature of the beast ?
