Subject: Re: Kremlin: Tip sizes WB enamel,acrylic
4/3/19
Mace Member
Hello,
I have a Kremlin 15C25. Looking to start spraying some WB products like SW-Emerald Urethane, BM-Advance etc.
Has anybody sprayed materials like this, and if so what tip size would you recommend?
Thank you.
4/3/19       #2: Kremlin: Tip sizes WB enamel,acryli ...
Jared Emery
The 15C25 is your pump. What gun do you have on it?
4/3/19       #3: Kremlin: Tip sizes WB enamel,acryli ...
Mace Member
Airmix Xcite 120 bar
With VX24 KHVLP Aircap
4/4/19       #4: Kremlin: Tip sizes WB enamel,acryli ...
Jared Emery
I have the same pump but haven't shot waterborne through it. Sherwin Williams' datasheet on Emerald Urethane says tip size should be .013 to .017. Cross-checking that with a Kremlin Airmix tip chart shows a #9, #12, or #14 tip depending on what you want for a fan size. They suggest an Xtra fine tip for waterborne.
4/4/19       #5: Kremlin: Tip sizes WB enamel,acryli ...
Mace Member
Thank you Jared.
Funny thing is i have sprayed those materials many times with my airless and I have never gone by the recommendations of the products. Not against it but I have never done well sticking to the labels. I use half the PSI they recommend and several sizes smaller than the orifice recommendation.
I did speak to my Kremlin rep and he thought I should try a #12 as you mentioned. But, he wasnt sure and with tips being so pricey I didnt really want to try on a guess. I thought maybe somebody on the forum had a tip they like to use. I'll try the 12.
Thanks again for your time and input.
4/6/19       #6: Kremlin: Tip sizes WB enamel,acryli ...
Brewster201
Scott there are quite a few #14 tips available for under $50 on eBay to start you journey
Bruce
