Subject: Re: Polyurethane over Nitro cullulose lacquer
4/6/19
chich Member
small piece to be painted. Just painted a small drawer unit that I made with Mohawk Nitro Lacquer. I have polyurethane on hand so rather than buying precat to cover it I would like to use poly. Am i gonna get into trouble here
4/8/19       #2: Polyurethane over Nitro cullulose l ...
mauricio poli Member
Yes, you are ! You can not do this, it will crack one day.
Never do this.
You can apply pu sealer and nc coat, this way no problem
Actually, it is better que use always the same chemistry on sealer and top coat, to avoid any problem or mistake
4/8/19       #3: Polyurethane over Nitro cullulose l ...
Paul Miller
I think the rule is you can put Poly over lacquer, but you cannot put lacquer over Poly. We have done Poly over lacquer without a problem. Putting lacquer over Poly will cause problems.
4/8/19       #4: Polyurethane over Nitro cullulose l ...
chich Member
thanks guys this cabinet was a rub thru so i wanted to seal the rub thru in after the lacquer but i decided to leave well enough alone. wasnt making much as it was so i had to buy clear lacquer, I had poly. It looks fine and I made a few bucks..Thanks guys Chow Mauricio!
4/9/19       #5: Polyurethane over Nitro cullulose l ...
Tom Norton
I have applied poly over lacquer by first applying a coat of dewaxed shellac. It has held up for 20 years.
4/10/19       #6: Polyurethane over Nitro cullulose l ...
You are welcome Chich !!! Have a great day !!!
4/10/19       #7: Polyurethane over Nitro cullulose l ...
chich Member
thank u professionals . sorry i spelt caio wrong Mauricio I know better Caio!
