Subject: Re: Spray Gun For Paint
Spray Gun For Paint
6/4/19
howard
Website: http://woodcontours.net
I currently use a Fuji hvlp for lacquer. I am doing a kitchen job with painted cabinet doors and I want to use a separate gun for this. What gun would you recommend for both the primer and finish coats? Thanks
6/4/19       #2: Spray Gun For Paint ...
dan shaf Member
Conventional air suppy (CAS) and not HVLP, and not LVLP. A regular gun. Two thin coats are way better than one thick coat. Unfortunately the call for paint aa a spec'd finish is happening more & more despite it's lack of durability. It's ridiculous.
6/5/19       #3: Spray Gun For Paint ...
CraigM
Don't use paint, use a pigmented CV or 2k polyurethane. For small batches I use a Binks Mach1 SL (HVLP) gravity gun with a 1.8 tip that works fine. For larger batches I use a CA Tech AAA pump.
10/30/19       #4: Spray Gun For Paint ...
Bill Colligan Member
Look into Benjamin Moore Advance. I have used it a few times out of a conventional hvlp conversion gun with amazing results. A standard hvlp gun is supposed to give excellent results as well. It flows out nearly as nice as the old oil based Impervo. The only downside is it has a long recoat period and full cure time.
